SOURCE: DYNEX DX - PD510 Portable DVD Player
I contacted Dynex via their website, I received a reply the next day will all sorts of "standard" things to do, clean the disk, make sure it is a disk for region 1, turn it on with the power supply plugged in, it may be moisture, leav it on for an hour with no disk etc. I had already tried all of these things including a 24 hour turn off, no joy, they didnt listen to the symptoms I had sent them. WHen I replied to them they said I needed to call their support line in the United States and they would assis me, I replied by email that a call from Aus to US would cost more than the unit if I had to wait in a queue and asked if we could please solve the problem by email, I have not had a reply and it is 5 days later. They acted like no one else has had the problem which of course is garbage, If I dont hear from them I will contact our Consumer Affairs people and make a complaint, they are still selling the DVD players in Australia, annoying isnt it?
SOURCE: Universal Remote Code for Dynex 20" TV/DVD
I just bought a 32" dynex lcd and saw that i couldn't program my two $5 ge remotes to work it. From reading in this forum and others I'm not the only one with the problem, I thought I was stuck with only the dynex remote. But the dynex website tells you how to get universal remotes to work,
It tells you to try the codes for Orion, Emerson, Memorex, Sansui, Sylvania, Zenith. The second orion code worked for me. both my ge remotes look and work the same but one uses a four digit code and the other uses a three digit code. I used 0135 on one and 135 on the other. There is a good chance that if you try the codes for the brands dynex lists you will find one that works. The 0135 or 135 might work for most dynex tv's.
If you have a ge remote and haven't programmed it for volume punch through you might try it. It allows the tv volume to be controlled using the ge remote even when it's set to something other than tv.
SOURCE: my plasma, lcd tv only shows in black and white
Would you say say the color is intermittent, sometimes black and white an occasionally flashes streaks of color? The small signal board may be at fault. You can ask to have the board replaced or fix it at the component level. Parts for the board at component level could be PN#823827736071 location 1H00, this is i beleive a color crystal, and two capacitors , PN#223886975478, location #s are 2H08 and 2H09. This repair is very prettymuch the repair you will need. Theses are surface mount parts and will require a tech to do. Hope this will give you a good start for repair!!!!!
SOURCE: Dynex 37" LCD TV bad color
You have a bad LCD control board going bad,Color getting floresent? Or pixely? esp. when you have it on for a bit. Common prop. But finding parts is a prob.
They are no longer in buis. Try Shop Jimmy,or even Ebay. Encompass does not have any. Runs about 40-60.
SOURCE: I have a DYNEX 32 lcd tv DX-LCD32-09 that was
The vertical lines from the top of the screen all the way to the bottom of the screen is the sign of the bad LCD panel, you need to find the receipt.
