Question about Bosch Drills
Bosch 11335K Jack hammer, motor runs, hammer doesn't
  • Bosch Master
  • 2,008 Answers
A ball bearing problem or broken piston drive rod ( its modificated by 1607000C3P) also best is to service with maintenance kit 1617000702
Posted on Sep 30, 2018
SOURCE:
brewerstool
  • 141 Answers
SOURCE: I have a Bosch brute jackhammer, I need the tool
You can use an adjustable face spanner wrench to remove that cap. I don't remember the pin size but you can measure the holes and get the appropriate size. You can remove the whole plate with the armature by undoing the 4 cap screws. Prior to removing the motor plate you have to remove the handle plate from the axle that goes through the body. Undo the nut that holds the assembly on and slide it off. You can now remove the Armature plate. After removing the cap screws pull the assembly out about 1-2 inches. You will see the wires that go to the field attached to the brush holders. Remove the screw that holds these wires to the brush holders. You can then safely remove the whole assembly. This also makes it easier to remove that cap plug with the spanner wrench, because you can now put the whole assembly in a vise. I always heat around the cap with a torch before doing anything. Then I tap on the plug with a hammer a couple of times and voila it turns alot easier. Corrosion almost always builds up on this cap because of the different metals. (Steel and Aluminum respectfully)
Your hammer may have a broken connecting rod. To inspect this make sure you ping the cylider and body with marks so you line them up the same way. Then remove the 4 cap bolts that hold the cylinder to the body. Remove the cylinder and inspect the hammer cylinder and rod. If the connecting rod is not broken you will have to inspect the gears and pinions to make sure they are ok.
Posted on Sep 13, 2009
  • 1407 Answers
SOURCE: How do I drain the gear oil from a Bosch Brute
Brute hammer uses special grease sold as service kit. This kit contains enough grease to lube hammer and replacement bolts that hold springs along the bottom. Check www.toolpartsdirect.com for parts and kit. Remove the lower half (tube) of hammer, also remove three bolts that hold springs and remove assembly from tube. Wash out old grease. Grease will be oil-like only when hammer is very hot, otherwise grease is paste-like. Good luck.
Posted on Jul 08, 2010
  • 1015 Answers
SOURCE: Bosch Hammer drill. When drilling, the
I would say that the motor shaft is probably bent and will need replaced.there are bosch service centers all over unfortunatly the price of parts especieally if it is a older unit can be almost what the unit costs.Sorry I'm not more help as I have several bosch tools in my shop and they are top quality tools. However I also have an old 65# electric breaker out there that is gathering dust because it has a cracked armature and the parts alone to fix it are in excess of $800.00. Best of luck to you and thanks.
Posted on Apr 18, 2011
  • 101 Answers
SOURCE: Bosch hammer drill 11239vs doesn't
none
Posted on Sep 01, 2011
SOURCE: Bosch Jack Hammer
I am an electrician, 230V means it is single phase. It would be 415V if it was 3 phase. It will have a 3 pin plug, if the centre pin is bigger than the top two it will require a 15amp powerpoint to power it. 3000W / 230V means it may draw 13 amps even though it has 9A on the tag. I would expect it to require a 15amp powerpoint.
Posted on Sep 30, 2011
Bosch hammer electric Hammer Jack is losing power and shutting off
The efficient design of Ingersoll Rand 114GQC Air Hammer allows the users to quickly change the spindles on the drill. It is able to deliver 2-5/8 inches of strokes with a BPM speed of 3500 so it ensures total efficiency.
Apr 05, 2018 | Bosch Hammering
How much grease goes in a bosch 11335k?
I believe this tool takes 225 ml of grease, but I would strongly recommend installing a service kit #1-617-000-702
The service Kit comes with grease and all the normal wear parts (highlighted below in black circles) Service Pack 1617000702 for Bosch Power Tool eReplacement Parts
Jun 16, 2014 | Bosch 11241EVS SDS-Max Rotary Hammer
Do you have to grease or oil anything on the bosch jack hammer
Grease bosch order nr 1 615 430 001 225 ml for 1 service OR 1 615 430 007 1000 ml for bulk repair.
Mar 16, 2013 | Bosch Brute Breaker Hammer 11304
I have a bosch hammer dirill that won't chip nor drill but motor run fine
Hi, have you tried the various positions on the front part of the gearbox behind the 'chuck'?
If so, then Im afraid it must go in for repair. These are not an easy fix and personally I would recommend you ask for a 'quotation' as it could be just something simple to do with the 'Gearbox' selector, but it could also be something a lot more serious within the Gearbox.
Good Luck & Best Wishes, John..
Jul 03, 2012 | Bosch 1" Sds+ Bulldog Rotary Hammer Drill...
Where can I find a 240v Bosch 11240 SDS Max Rotary Hammer drill that I can take and use in Ghana
You'll be hard pressed to find one that doesn't run on 110v. You might be able to look on ebay and buy something from the UK like this for example:
http://www.ebay.com/itm/Bosch-GBH4-32DFR-NEW-Multidrill-4Kg-Rotary-Hammer-With-Accessories-240V-/160648807099?pt=UK_Home_Garden_PowerTools_SM&hash=item25676a42bb
Or you could just get a power adapter. Make sure they will work for the amount of amps that the tool will be pulling.
Mar 20, 2012 | Bosch 1 916 SDS Max Rotary Hammer Drill...
How do I drain the gear oil from a Bosch Brute Jack Hammer
Jun 22, 2010 | Bosch Brute Breaker Hammer 11304
Breaker Hammers Features
power, raw strength, comfort and vibration
Aug 27, 2008 | Bosch 11335K Factory-Reconditioned 35 lb....
Drills Logo
276 people viewed this question
Top Bosch Drills Experts
John Trevino
Paul Carew
Lance Guthrie
Lance Guthrie
Level 1 Expert
Are you a Bosch Drill Expert? Answer questions, earn points and help others
