Question about iLO Televison & Video
Jow Do I Switch My Ilo Tv To The Line 1 Input Using A Universal Remote
    Top Expert:
  • iLO Master
  • 52,791 Answers
Your URC may not be capable of selecting line 1 input. URCs do not necessarily provide full functionality.
Posted on Sep 27, 2018
SOURCE:
  • 19 Answers
SOURCE: universal remote with my ilo
tvs are made for wal mart from more than one mfg
Posted on Nov 27, 2007
SOURCE: ILO universal remote code
I had the same problem trying to program my satellite remote to work with the ILO tv. I found that the emerson codes DO work. Yes local cable remotes will work as long as you have the code and the brand is getting more popular. The code that worked with both cable companys, Charter and DirecTv was 10171 I believe. You can find it under the Emerson codes. Hope this was helpful.
Posted on Dec 07, 2007
  • 1694 Answers
SOURCE: GE universal remote for Ilo brand tv
www.remotecodelist.com ...........................................T.
Posted on Mar 22, 2008
SOURCE: code numbers to set up iLo tv
Checked on line for any code there was that someone used for iLo t.v.'s, found two codes on your site that someone had used & used those & one of them worked. Thanks again!
Posted on Apr 02, 2008
  • 3 Answers
SOURCE: ilo tv/universal remote codes
Here are some to try, mine was 0189, but there are many to try. 0051 0189 0053 0198 1070 1024 1023. I think some listed codes for Emerson work as well.
Posted on Aug 06, 2008
How to switch the input mode without the remote
most sets have a source or input button on front, side, or in main menu--if not you are out of luck unless have the original remote control--forget a universal.
May 19, 2012 | iLO IWT3206 TV
How to switch to av rca input channel
hi melinda,
u can go to av input by simply pressing the VIDEO button on ur remote. when first time u press the first input may select. press again and again until u get desired input. normally rca input may be video 1 , or video 2 . first check which input are u using. select the same using remote. To return to tv mode just press TV button on the remote.
ok
Dec 13, 2010 | iLO 2600 Television
Rca universal remote (#rcu600ds) no code for ilo tv
I called the number on the Ilo TV. 1-800-289-0980. They suggested trying the codes for either ILO, Orion or Sansui. I got the Orion Code 0135 to work with my new GE remote.
Feb 06, 2010 | RCA Universal Remote Control
Need a manual and remote control for an ilo LCT 42HA36 TV. We are using a universal remote. Cannot control the picture size to adjust for HD. No control over the mono stero which pops in and out. Cannot...
Look on line and see if you can find a phone number or a way you can order a new remote and a neew control for your set.
Note:Most televisions will operate from a universal remote but you wont be able to do any major changes with it.
Oct 23, 2009 | iLO LCT32HA36 Television
Ilo tv remote control
So far the only universal remote that I have found that works on these TV's is the GE universal remote #24914. The code for the ilo is in the book that comes with the remote. I use this remote...I am able to switch from analog to digital with this remote to. I bought the remote from Target for under $10.
Jun 09, 2009 | iLO IWT3206 TV
Vid
well this probally newer set try to find universal remote and progam and if there are alot of codes for the set make you go thru every one make sure that universal remote has video input button
not saying it will work for ya but its better than buying new remote thru ilo try that to if first sympton does not work good luck
May 03, 2009 | iLO IWT3206 TV
Need to switch to dtv from reg tv but dont have fac. remote
most universal remotes will only do basic functions on your tv like changing volume or channels only some will do menu functions or change input source. if you have a universal remote with a input or source button you can try it some cable and satelite remotes have this function and are discribed in the user manoal. If all else fails you can order a original remote from the manufacture or your local tv repair shop
Apr 27, 2009 | iLO 3200 32 in. LCD Television
I got a ilo tv and i cant figure out what the code is for a universal electronics remote help
The only remote I was able to find that work all Ilo features is the GE universal remote #24914 works to change your Ilo tv from analog to digital and switch to vid1 or vid2 ect.... The code is in the book that comes with the remote. I use this remote myself. This remote can be bought at Target for under $10.
Apr 19, 2009 | iLO IWT3206 TV
Need remote control code fro iLo TV
iLo Tv's are made by orion. When I used their code the Tv remote worked.
Dec 07, 2008 | iLO 2600 Television
72'' LCD Ilo won't switch inputs
By a learning remote. Go to WalMart borrow the Ilo remote and use it to teach your learning remote. Simple!!
Jul 31, 2007 | iLO 3200 32 in. LCD Television
Televison & Video Logo
Top iLO Televison & Video Experts
Steve Allison
Steve Allison
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
