No you can't. The AI Answer Bot Raja Azeen is incorrect in his guess. The Bose Accoustimass has a surround sound processor, but you are only using the speakers. The Denon receiver is collecting the signal and that is already an amplifier and then you are pushing it into the Outlaw amp and pushing that signal further and into your poor speakers. Stereo is the best you will get through 4 speakers but not the phased processing that you should get.
You need to use the IR emitter that came with the Bose V30 system. Bose employs a proprietary RF frequency remote which communicates to the hidden central control head. You plug in the emitter to the processor unit and run the emitters to the IR 'eye's' of the equipment you want to control. Once all this is done then and only then can you go through the remote codes to control a particular device. The Bose V30 has 2 IR emitters that come with the unit to control 2 devices. You can expand on that buy buying a IR emitter bridge that has several inputs for other devices.
Now when it comes to a DVR I am not so sure the Bose universal remote will work all the playback and FF and record control buttons and a DVD or VCR. I hear there is a new BOSE remote on the market that can do that but I have yet to see it in person or ask a sales rep about it. Sometimes they are non-tech's so its no help : (
Make sure the power supply is connected properly. If the power supply
is connected upside down or sideways, the system will make a thumping
noise, or will not play at all. However, no damage will be caused by
connecting this wire incorrectly.
You will need to connect the speakers to the front channels as you would with any normal set(Speaker + to amp +, speaker - to amp -, etc) then you connect the special Bose equalizer through a tape monitor loop and always have the monitor loop engaged.
There's a line fuse inside the radio, mounted on a PC board. CAUTION:
disconnect the set from power before opening the case or poking around
inside. The fuse could be bad, but these sets are notorious for losing
the power transformer. If the fuse is ok then you are looking at a
$100 repair fee from Bose. You might want to check out the new HD radios -- better sound, MUCH lower price.
There's good news and bad news. The bad news you need a separate amp because a multichannel receiver with Bose 901's attached as recommended for a standard stereo receiver will only sound right in STEREO on stereo analog material. The other speakers around the room are not designed to receive its Active Equalization and if you engage your Tape Monitor you will NOT BE ABLE TO HEAR DIGITAL sources at all. Tape Monitor is for analog stereo material only and on modern AV receivers it disables any digital inputs so you really can't use the Tape Monitor circuit or attached devices for modern digital sources. However, you can still employ the Tape Monitor with any type of stereo-only sound processor (non-Bose EQ, dbx expander, etc) and the various DSP options to spread 2-channel analog source material around the room. I have a whole stack of analog processors, tape and CD recorders slaved to my single Tape Monitor and then into a dbx400x Program Route Selector. It not only expands my Tape Monitor to handle nearly unlimited external devices but it makes routing for listening or recording easy with simple pushbuttons. But I digress...
The good news. I have a setup similar to what you want to do and it works great! With one caveat - My receiver actually has 5.1 analog Outputs (probably like yours) so I can drive up to 6 external amplifiers if I want to (I drive 4).
A separate stereo amp for the 901's was my solution. I run a Carver AV-406 (5-channel amp) for my 901's in Front, 2 Subwoofers and the Rear Surround channel, with the Active EQ between the receiver Front L&R Outputs and the 901's amp channels. My receiver controls everything and just drives the Center and Surround speakers.
You could get by with just a stereo amp for the 901's. A Carver M-200 is a good efficient amplifier that would have you cooking just fine (2x100W). Run it with the Active EQ between the receiver Front L&R Pre-Outputs ** and the 901's amp channels. ** Front L&R Pre Out >>> Bose EQ Amplifer IN, then Bose EQ Amplier OUT >>> NEW amplifier IN.
Attach the 901's to the new amp, set its volume to Max and run through your receiver's speaker level setup.
No. You would need some kind of audio out connections on the back of the media center. The only audio outs it has are the Acoustimass® Module – SPDIF connector.
Unless you were to hook up an amp before the Bose media center. In other words, you could run your TV to another amp's line in. You would hook up additional speakers to this other amp, then run audio line outs to the line in of your Bose media center. Some stereo amps have a line out or record/tape out, it is from here that you would run the cables to your Bose media center line ins. The disadvantage to doing it this way is you would have to plug all your media devices (dvd, tv, etc) into this amp first and your Bose remote wouldn't let you switch between devices. If your media devices you have offer digital audio, then you would want an amp that also offers a digital out for the best sound. Otherwise you will end up with analog out from this amp to the Bose media center and thus lose any of the digital signal information like surround information. So there isn't much point in doing this. If your gonna get an amp that has all the digital in's and out's, you might as well just use it with new speakers and forget the Bose system you have.
