SOURCE: What is the capacity (Size) of the Speed Queen Marathon Washer?
Pi,r,squared times height. Remember math back when we didn't have computers? So that's 3.14 x radius(half the distance across drum)squared(times itself) times height or depth of drum. Remember to do radius times itself first, then Pi, then height.
SOURCE: Queen marathon 20 years old does not pump the
If the motor is running then the water pump or the clutch to it has failed. If the motor is not running, the motor has failed. Both fixes are probably too expensive for a 20 year old machine. Unless you are very handy and resourceful it may be time for a new machine.
SOURCE: SPEED QUEEN WASHING MACHINE LEAKS WATER WHEN IT STARTS WITH WASHU
check hoses and pump area.
SOURCE: I have a Speed Queen Marathon washing machine..The
Maybe look on the belt, to see if there is a same number on it. take it to a appliance repair dealer get him or her to check for you
SOURCE: Speed Queen top loader leaks from top of tub at large load spin c
make sure unit is level possibly lower front legs down so front sits higher,,, and also when u put or load in push the tub back so when the water enters it all enters into the tub sometimes the water will splash on the tube and cause a problem u are discribing hope this help
