Question about Polaroid Cameras
Polaroid Is 826 won't turn on. I've been charging it for hours. Its barely used.
2 Suggested Answers
SOURCE:
youngdroop34
  • 11 Answers
SOURCE: Motor won't engage. I turn the throttle and get a clicking sound, but nothing happens. We've charged the battery for about 4-6 hours, but the light stays red, never turns green. Help?!!
sounds like the battery is bad and not taking charge.replace battery attemp again if not then check for fuel, spark and compression.then c wat happens or wats not working any motor no matter how small or big has to hv those three things to run. hope this helps.
Posted on Jul 08, 2012
Won turn fully charged battery
You sure your battery is fully charged and still good?
on the other hand Sony Cyber-shot's are known to have this problem.
Try pressing the on button for 5sec
Nov 24, 2017 | Sony Cyber-Shot DSC-WX9 Digital Camera
Switronix Tl-50 won't turn on
I too have had a problem with mine no longer charging. I talked to the manufacture. Since the cord light is on however my torchlights charging light is not on they said could be the batt or could be a bad wire in the charger. I've been debating whether to send it in for fix or buy a new batt to try first. For yours I would send in for repair. Unfortunately these lights only come with a 1 yr manufacturing warranty so if you've had it over a yr you will end up paying 60-130 was the price range I was quoted depending on the problem.
Mar 03, 2013 | Switronix TorchLED TL-50 Video Light - 75...
I just bought the eclipse cld and it won't turn on after charging for hours
If the rechargeable battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Sep 30, 2012 | Eclipse Audio Players & Recorders
Jul 08, 2012 | Electric Razor Pocket Rocket Ride-on...
My, 2008 kawasaki ninja 250, gas tank won't open. When I insert the key, it won't turn. I've pushed and fidgeted it as much as possible to the point before breaking the key in it. ...
Hey Simon,
I would haul it to a local (GOOD) locksmith, they will get it open..
Are you 110% SURE it the RIGHT key???
Good luck...
Jul 27, 2017 | 2008 kawasaki Ninja 250R
My polaroid A800 will not hold a charge. After taking a few pictures the batteries go dead. I use Polaroid batteries.
The Polaroid are good batteries, but! by your description they need to be replaced because it won't hold a full charge.
Apr 22, 2011 | Polaroid a800 Digital Camera
The S107 helicopter charged up successfullyfirst time using an Apple USB mains adaptor. I then tried charging it up from a computer USB and it would only partially charge with the machine turned on and the...
Is helicopter off when charging? Will not charge when powered on.
Light on charger should go off when plugged into helicopter.
Also, are you running battery dead? This will destroy a Li/Po battery. Never fully drain battery. Run only until you cannot maintain altitude. Land and power off. Cool for 10 minutes. Charge. Cool for 10 minutes. Skipping either "cool-downs" will also destroy your battery, albeit slower than the full discharge which can sometimes kill a Li/Po battery in only 1 or 2 cycles especially when they are new. Have any friends with a cell phone or laptop (Li/Po batteries also) that they hate because "it's always dying" or "the battery only lasts like 4 hours" whether or not they know why, it is ALWAYS because they rarely charge them fully, especially for the first few charges which are crucial, and the often run the things dead until they won't even turn on.
Back on topic, I use and recommend the usb power adapter. When plugged in using the USB wall adapter, does the charging light still stay on? Certainly if "yes", and still likely if "no" sadly, this to me sounds like a fried battery, which, if it, as I suspect, was caused by frequent or early full discharges and/or hot charging/flying... then you're screwed. The batteries are cheap but quite tricky to replace. Need a steady hand and a needle tipped soldering iron and solder barely thicker than hair.
Hope I've helped,
PvT
Jan 04, 2011 | SYMA Toys industrial New Syma S107 Mini...
Cameras Logo
93 people viewed this question
Top Polaroid Cameras Experts
Damen Wong
Damen Wong
Steven Wander
Steven Wander
Marvin
Marvin
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
