I rebooted or factory reset my laptop then closed the laptop after powering down and now every time I try to power it on it says that there was an errer
SOURCE: ACER ASPIRE 5100 LAPTOP POWERS ON AUTOMATICALLY AT RANDOM TIMES
BIOS setting for automatic power on?
SOURCE: my hp laptop keeps rebooting
it sounds like your hard drive has failed. you need to replace your hard drive and reinstall the operating system.
hope this helped.
please remember to rate my service.
If you need further help, reach me via phone at https://www.6ya.com/expert/mark_445a24324be9eb03
SOURCE: Toshiba Satellite A205-S5814 laptop will not power on
clear the bios by removing the small battery on the mainboard for 10 hours.the power on
SOURCE: light blinking when power button is presed but laptop not coming
There is no software that can make the computer fail before the BIOS posts. Very little that won't at least allow the kernel to boot. So you can always at least get to the BIOS which loads from a chip, not from your drive.
If you can't, it's definitely a hardware issue and you should begin standard hardware troubleshooting on the board. If you can, boot to a utility CD/DVD and test the drive. The computer uses virtual memory which constantly shifts portions of the operating system between the hard drive and RAM. This means a heat related failure can also corrupt the data on your drive, cause restarts during RAM intensive processes like an install, and cause funny behavior.
Heat related damage is the most common problem in
laptops because they run fairly hot and people like to use them on beds
and couches which are soft and therefore block the vents. When laptops
don't ventilate properly the memory, video, and hard drives will be the
first to fail.
Be prepared to have to reload your OS and all your software if this is the case. Recovery can be very hard.
