Televison & Video Logo
B
Bonnie Bailey Posted on Sep 26, 2018
DirectTv. please answer my question that I have already sent now twice.... on my channels it says...Program can’t be fast forwarded, pressed Exit twice and it keeps returning, now What?
3 Related Answers
LG help guy
  • 112 Answers
  • Posted on May 22, 2010
SOURCE: WHAT SHOULD THE RETURN/EXIT BUTTON DO ON MY REMOTE IT ONLY SEEMS
If you look on page 48 & 49 of your LG TV’s user manual, you will see your TV remote and a description of the buttons.
Your particular remote does not have a previous channel button or function. That backwards arrow button is to return one step in an interactive application or other user interaction functions.
However, if you get the full size LG TV remote it does have a “FLASHBK” button that will go to the prior channel. Some programmable TV remotes have this feature too.
You can go to the TV store and ask to use the larger LG TV remote that has the “FLASHBK” button on your TV on display to see if your TV will perform that function.
Good luck.
Anonymous
  • Posted on Jun 21, 2010
SOURCE: Teac HDR2500T Fast Forward/Rewind problem: It
easy, download the software update from the teac website- had the same problem myself
gopakumarg43
  • 76851 Answers
  • Posted on Nov 07, 2014
SOURCE: How to remove program from tv screen? When l
Try a reset to this set, and check. There are two types of reset to TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight; will be better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
How do I set up my clock on Panasonic Omni vision vcr without a remote controller
You can set up the clock on a Panasonic OmniVision VCR without a remote controller by using the buttons on the front panel of the VCR. The process may vary depending on the specific model of your VCR, but in general, the steps are as follows:
  1. Press the "Menu" button on the front panel of the VCR.
  2. Use the "Channel Up" and "Channel Down" buttons to navigate to the "Clock" option and press the "Enter" button.
  3. Use the "Rewind" and "Fast Forward" buttons to set the hour and press "Enter"
  4. Use the "Rewind" and "Fast Forward" buttons to set the minutes and press "Enter"
  5. Press the "Menu" button again to exit the clock-setting menu.
I can't seem to be able to fast forward any more than twice speed. I know there is some way I can program it that it allows me to be able to do that but I can't seem to find in the manual where I...
Hi Henry,
  1. Usually DVD players DVD players come along with remote controls which have fast forward buttons which have the icon as ">>" .
  2. All you need to do , is press the button as per your requirement of fast forwarding.
  3. If you press the one, you would get a message as x2 on the TV screen and if you again press it , it would display x3 and if you press the button again it would show x4 , that is the maximum speed you can have usually for fast forwarding.
  4. So the solution is to keep pressing the button multiple times to change the fast forward speed.
Hopet his helps ...Your feedback would be appreciated.
I need the universal codes for my verizon fios remote, otherwise another recommendation of a universal remote that will operate my tv.
Setting up the Philips RC 144 remote if the remote codes are invalid or unknown If you do not know the remote codes for a device, or if you've tried all the listed remote codes for your device and none of them work, you can search for the correct remote code by following the steps below.
Note: These steps only apply to the Philips RC 144 Remote Control. If this is not the make and model of your remote, go to the supported remote control models page and find the instructions for your specific remote control.
Searching for a Device Code
  1. Turn on the device you want to program into your remote, for example if you are programming your remote to control your TV, then turn on the TV.
  2. Press and hold the device button for the device you turned on in step 1 (DVD, AUX, TV, STB) and press OK. Release both buttons.
    The mode buttons blink twice.
  3. Press 922.
  4. Point the remote control toward the device you are setting up and press the upper part of the Play button.
  5. Press the Fast Forward button. If the device you are setting up does not turn off, keep pressing the Fast Forward button until the device powers off. (You can use the Rewind button to go back, if necessary.)
  6. When the device powers off then you've found the correct code for that device. Press OK to assign the code in your remote control.
  7. Note:
    There are over 200 possible combinations for TV and DVD codes. The most common codes are tried first but you may still need to press the Fast Forward or Rewind buttons over 200 times to find the correct code for your device.
    If you reach the end of the list of codes, the entire remote flashes twice and returns to normal operation. You can exit programming at any time by pressing the Exit button.
Where can i get the channel list for my eurovox EX5100 pvr blue
Hi, Please try the below mentioned steps: AUTO SORT OFF B4 U MANUAL SCAN A CHANNEL/S: Go into Menu / Installation / Fast Install and press OK (enter pin) Now press the red button on the remote for advanced install Scroll down the options and turn Fav Sort off then press exit (do not press OK) if you press OK all channel order will get sorted back to the default order MANUAL SCAN ALL CHANNEL?S: follow AUTO SORT OFF After you press exit you get a list of frequency?s press red button (update) to update all channels MANUAL SCAN ONE CHANNEL: On the channel that?s scramble press the info button twice and make a note of the frequency at the top left, now follow AUTO SORT OFF when u press exit u get a list of frequency?s scroll down till you get to the frequency you made a note of and press ok to tick the box then press blue button for manual scan else....do a factory reset on the box m8 then rescan for chanells then leave your box on sly sports 1 to update
JUST BOUGHT AN OPEN BOX TOSHIBA T.V. MODEL #26LV61OU LCD-HD AND IT DIDN'T HAVE A REMOTE. IT'S WORKING WITH MY VERIZON FIOS BUT I CAN'T CONTROL THE SOUND. WHAT TYPE OF REMOTE SHOULD I GET FOR THIS T.V. AND...
The remote that came with your Verizon FIOS can be programmed to control the sound on your TV. There are four different remotes can come with Verizon FIOS, and there are three different procedures to program them. I will give you all three to print out try to fix your remote control problem.
Does your remote look like either of these two?
If so you have a Philips universal remote. Here are the steps to find the code that will control the sound on your TV:
1) Turn on the device you want to program into your remote, for example if you are programming your remote to control your TV, then turn on the TV.
2) Press and hold the device button for the device you turned on in step 1 (DVD, AUX, TV, STB) and press OK. Release both buttons. The mode buttons blink twice.
3) Press 922.
4) Point the remote control toward the device you are setting up and press the upper part of the Play button.
5) Press the Fast Forward button. If the device you are setting up does not turn off, keep pressing the Fast Forward button until the device powers off. (You can use the Rewind button to go back, if necessary.)
6) When the device powers off then you've found the correct code for that device. Press OK to assign the code in your remote control.
Note:
Does your remote look like this?
If so, your have a Motorola universal remote. These are the steps to find the correct code to control your tv:
  2. Note: The DVD/VCR button can control a DVD, VCR, or a combination TV/DVD, TV/VCR, or TV/DVD/VCR.
  3. Press and hold for six seconds the device button for the device you turned on in step 1 (AUDIO, DVD/VCR, TV, CABLE).
  4. The lights for each device button light up and the light for the device button you selected remains on.
  5. Press the Power button on your remote.
  6. The device button blinks three times then turns off.
  7. Press the Up arrow button (this is the button directly above the OK button, not the Page Up button).
  8. Did the device turn off?
    Yes: Congratulations! You've found the correct code for that device. Press OK to store the code in your remote control.
    No: Repeat step 3 and 4 until your device turns off, then press OK to store the code in the remote control.
    Note: To retry the previous code, press the Down arrow button (not the Page Down Arrow button).
If so, you have a Scientific-Atlanta universal remote. Here is how to find the control codes for your TV:
  2. Press and hold the Select button while also pressing the device button for the device you turned on in step 1 (AUX, DVD, VCR, TV, CBL) until the device button blinks twice.
  3. Press 991.
  4. The mode button blinks twice.
  5. Point the remote control toward the device you are setting up and press the Play button.
  6. The remote control tests each code in its library. The mode button blinks once each time the remote transmits a new code. When the last code is reached, the mode button blinks twice.
  7. When the device powers off, press the Select button.
  8. Verify the new code is correct by pressing the Power button.
    Did the device power on again?
    Yes: Press Select to assign the code in your remote control.
    No: Turn the device on and press the Channel Up or Channel Down button to step forward or back to the correct code. When the device turns off, press Select to assign the code.
___________
One of those three should work for you.
Hope that helps.
1helpful
I have DirectTV and a DirectTV remote RC64. I can
Here are all the codes I have
10171 10096 10187 10020 10381 10024 10030 11314 10186
here is how to set up without a code:
mode switch set to TV
PRESS & HOLD Mute and Select buttons at the same time UNTIL light blinks twice
enter 9911
keep pressing channel up until the channel changes on the tv
Maker sure to test the VOL button, if volume works
PUSH select key to set the code
THESE PROCEDURE CAN BE USED WHENEVER A REMOTE KEY IS NOT AVAILABLE.
CHANGE THE LAST NUMBER, 1 TO
2 for AUX1 (VCR and DVD)
3 for AUX2 (Audio Devices)
1helpful
Fios code for Winbook TV
If you do not know the device codes for a device, or if you've tried all the listed device codes for your device and none of them work, you can search for the correct device code by following the steps below.
  3. Press 922.
  4. Point the remote control toward the device you are setting up and press the upper part of thePlay button.
  7. Note:
Forward fasts on its own
you may want to try fast forwarding at 2x (that is, press the FF key twice), although the speed will be faster, it may actually stop for you, when you press play, rather than going to the end.
3helpful
6answers
Why can't I find the codes for DirectTV remote?
Find your rca sat. remote code under the mitsubishi code list in the RCA sat. booklet, it worked for my Polaroid 42" dtv. My prob. is finding the sat. code to program the remote which came with the Polaroid DTV. If anyone has this code please post it.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
