Question about Jensen VM9410 Car DVD Player
Moniter does not come out
My kids put several cd in then I ook it apart and ripped an electronic band that seams to work the moniter I need to know where I can order tha part because I opened the unit and my warranty is probbably no good anymore please email me at
  • timsautos Sep 30, 2008
    i need the same part the cord broke from wear of the unit going in and out
I got the same problem send me a solution?
Posted on Aug 23, 2008
Heater core flutes replace
Frank, No ones knows what your talking about here in the USA. Except junior high school kids in band and possibly me. So here you go. Two possibilities, both apply with flutes. Lets start with plenum doors. They are inside the air plenum, you have the remove the entire dash and plenum to replace them, several in there. If you only have defrost blowing, it could be a vacuum line or the A/C controller is bad. If you are talking about the vents mounted to the dash, look at them, they usually pop out. Look for the seam around the vent. Use a plastic wedge to pop them off/out. It won't damage the dash. Some are screwed into the back side. In this case you still have to remove the dash.
Jul 26, 2015 | 2000 Nissan Frontier
How i can use cd player of toyota ist 2004 model
just put cd in should start if it doesn't iv have found kids like to install change in them iv taken a few apart and found coins in them if not its just bad does sometimes happen
Feb 10, 2015 | Toyota Cars & Trucks
Pisen USB Hub burned out and wont work
Look for a seam around the case, scrape the plastic until you can pry it apart. This usually results in destroying the case and quite messy and sometime even dangerous (sharp knife, unprotected hands, slippery surfaces). From my experience liking to take things apart, and being a major Band aid user, its not worth it.
If it s done for, you might as well use a large screwdriver and force it apart from where the wires go into the case. It cant be repaired, get a new one.
Mar 30, 2014 | Generic Pisen Multi Purpose USB Hub, White
The screws holding the face for my speedometer came out. Is there a way to take apart the speedo and fix the problem?
Typically the upper and lower half of the speedo and tach are held together with a metal band that is folded over the lips of the two halves. to separate you will have to carefully cut the band (usually on the bottom,towards you), peel it of trying not to kink it(save for later) and two halves should easily separate. Clean, lubricate,screw,etc. Put band back on, put a spot of glue at cut seam (only)and carefully wrap band with tape( electric works good)to hold speedo band and halves together.
Jun 02, 2010 | 1980 Honda CX 500 A
I have the portable cd players in my classroom for students to listen to books on cds. One of the students dropped the disc won't spin. Can I take it apart and fix it?
Chances are either the motor became disconnected - which just entails opening it up and looking for anything that might have came loose; or it's completely broke which would be more trouble than what it's worth.
What I would do is hit up craigslist or ebay to find a slightly used CD player, or even local small electronics shops should sell them relitavely cheap.
Another thing is that small electronics shops love the oppertunity to advertise. With that being said, ask them if there was any way that they could do media donations to local schools and let them in some way put their business info on it. Get the name out and recognized. Then, when another breaks you have spare to use, and if you get enough donations, as an end-of-year gift give the player to each kid. - Just an idea.
Good luck and let me know how things work out!
Please give me a good rating if i've helped you out!
Mar 26, 2010 | Audio Players & Recorders
PCDJ Blue won't run
If you want to rip cd's use ashampoo music studio or xilisoft products as alternative as PCDJ is not compatible with all pc's and if you are using vista then on the UAC you need to permit the install or it wont work.
Feb 23, 2009 | Visiosonic PCDJ Blue Pro DJ Software...
Get Moniter Speakers Working
Hello First of all you need a sound card on your computer with a Spk. (Speaker) or Phones (headphones) Out Jack it might be a symbol of a small speaker or headphones. You have to be sure you are getting a actual sound output signal from this sound card too. If the sound card is not working your moniter speakers would not have a signal to drive it. You also need a 1/8" Stereo 2 male stereo plugs on both ends, one end plugs in back of moniter other plugs in back of computer like I mentiond above. Make sure your Mute button is not selected on your computers volume button usally at bottom right of screen. Make sure the volume buttons are up to aprox 3/4 up also. Then for last on the moniter look in the menu i think you might have to keep pressing the menu button but i kind of forget now but its a Spk setting and volume setting in this speaker setup within the moniter as well make sure this is turned on and set at a higher volume level as well. Thats about all I can say without taking the moniter apart and checking the jack and wires and speakers. I would suggest you take it to a electronics or a tv repair or computer repair person to go any further then this. Hope you take time to read all of this I tried to put every step in here to help anyone out with this problem. Thanks for reading. Ken T
Nov 08, 2006 | Liquid Video A170E101 Monitor
Scanning Sensitivity
Tony ,what your Expericing Is Bad Solder Connections,The Scanner Needs to Be Taken apart and gone over with solder,Litttle Breaks Can detune the Pll Circuit and Cause what your Having Please let me know if this Helps
Aug 18, 2006 | Radio Shack Pro-96 Scanner
Jensen VM9410 Car DVD Player Logo
48 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
