Dishwashers Logo
Tommy Mannion Posted on Sep 25, 2018
Below DW600 dishwasher all the program lights stay on and won't reset
cornfuzzle
Level 1:
Scholar:
New Friend:
  • Contributor 28 Answers
  • Posted on Sep 25, 2018
cornfuzzle
Contributor
Level 1:
Scholar:
New Friend:
Answers
28
Questions
0
Helped
11969
Points
79
A standard control panel reset should work:
1. Find the Start/Stop button on the panel
2. Press and hold for 3 seconds to cancel any "stuck" program that thinks it's running.
3. Wait 10 seconds.
4. Press and hold for 7 seconds to reset.
Don't be too stingy with those timings ;)
Testimonial: "I have tried what you suggested but lights are still on can you suggest everything else to try please"
  • 1 more comment
  • Tommy Mannion
    Tommy Mannion Sep 25, 2018
    I have tried what you suggested but lights are staying on can you suggest something else I can try
  • cornfuzzle Sep 25, 2018
    Sorry - that's the standard "user" solution. I hope someone else can help otherwise you'll need to make a service call. (That's ok if it's under warranty but otherwise I'd get an estimate before someone heads out your way.)
    I hate to mention this, but I assume you have turned off the power supply and left it for a few minutes. Thought I'd mention it just in case.
How do I change the waste pipe on a dishwasher dw600
follow the pipe iced the machiene and there is a sprung clip like a jubilee clip holding it on ..... you'll need a pair of pliers to squeeze it together
Purple light is on and cycle won't start
It's possible that you have put the dishwasher into delay mode. Try powering off at the powerpoint as this will force a reset of all programming.
The pause/start button also sets the Delay Start feature which can delay the start of a wash program
from 1 to 12 hours.
To cancel Delay Start
Press the I button.
My Beko DW600 dishwasher heater is stuck on!
You can't reset them, you just buy and fit a new one. The contacts can arc and they stick together.
https://www.google.com/search?q=Beko+DW600+dishwasher+heater+relay
Sep 21, 2012 • Dishwashers
1helpful
Just installed beko dw600 dishwasher and ran empty on economy cycle as directed. After 4hours machine still running? Do you physically have to switch machine off?
The econo cycle is the shortest cycle on the dish washer. You have a mainboard issue with it or something. Most cycles on newer dishwashers take 2 hours.
Mar 15, 2012 • Dishwashers
My beko dishwasher is not rinsing properly, we add rinse aid and salt and the pots still come out with **** on then and are not being cleaned properly even on the hottest wash
Try running a dishwasher cleaner through it, it will break down any built up residue in the machine, with using salt to soften the water it can build up in places and reduce water flow.
Mar 06, 2012 • Dishwashers
How long is the discharge hose suplied with the Beco dw600 dishwasher & can this be extended.
The one available is 1.5 meters. See this site. You cannot extend this according to the installation guidelines.
Mar 03, 2011 • Dishwashers
Water won't drain
Do the diagnostic test:
SHU 53 MODELS
To start test program, press and hold both SCRUB WASH and DELICATE/ECONO program buttons, then turn unit on by pressing ON/OFF button. Initially, control module version # will be displayed (e.g./ ?21? = version 1 with jumper). When wash program buttons are released, lights above them will flash. To end test program, press ON/OFF button.
To check each program indicator light, press its button. To check Cycle Countdown display, Refill Rinse Agent light and REGULAR WASH light, press REGULAR WASH button (press Delay Start button to test Cycle Countdown display alone). Cycle Countdown display will show “88′ when REGULAR WASH button is pressed and “8h” when Delay Start button is pressed.
To start testing, press both the SCRUB WASH and DELICATE/ECONO buttons a second time. When testing has ended, Cycle Countdown display will show a fault using codes below. If more than one fault occurs, code numbers will be added together, (e.g./ ?6? = faults 2 + 4).
0 = No faults detected 2 = Heating fault 8 = NTC (temperature sensor) fault
1 = Aqua Sensor (“Sensotronic”) fault 4 = Filling fault F = Filling fault (display occurs during wash, not test)
To check for heater, high limit or flow switch problems, start testing until heating starts. Using a meter with a current coil, measure current going into dishwasher. If current is ~ 11 A, then heater, high limit and flow switch are OK. If current stays at ~ 1.5-2 A, then heater, high limit or flow switch are faulty.
If water level switch (f1) has failed (opened), display will show fault code “4′ and unit will continually fill and drain where testing won’t be completed. If flow switch (e5) has failed (opened), display will show “0′, water won’t heat (to 150?F) and water won?t stop circulating. If NTC probe (f2/f4) has failed (opened), display will show fault code “8′ immediately and testing will end shortly after water has started circulating.
The dishwasher not draining is most probably faulty drain pump or drain hose is got bit loose.It has to be checked and confirmed
.You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
1helpful
The dishwasher has been running for 3 hours and seems to be stuck on 1 minute left. Upon opening, there was sudsy water remaining in the bottom, but the dishes looked clean. The washer just won't go to...
SHU 53 MODELS To start test program, press and hold both SCRUB WASH and DELICATE/ECONO program buttons, then turn unit on by pressing ON/OFF button. Initially, control module version # will be displayed (e.g./ ?21? = version 1 with jumper). When wash program buttons are released, lights above them will flash. To end test program, press ON/OFF button. To check each program indicator light, press its button. To check Cycle Countdown display, Refill Rinse Agent light and REGULAR WASH light, press REGULAR WASH button (press Delay Start button to test Cycle Countdown display alone). Cycle Countdown display will show ?88″ when REGULAR WASH button is pressed and ?8h? when Delay Start button is pressed. To start testing, press both the SCRUB WASH and DELICATE/ECONO buttons a second time. When testing has ended, Cycle Countdown display will show a fault using codes below. If more than one fault occurs, code numbers will be added together, (e.g./ ?6? = faults 2 + 4). 0 = No faults detected 2 = Heating fault 8 = NTC (temperature sensor) fault 1 = Aqua Sensor (?Sensotronic?) fault 4 = Filling fault F = Filling fault (display occurs during wash, not test) To check for heater, high limit or flow switch problems, start testing until heating starts. Using a meter with a current coil, measure current going into dishwasher. If current is ~ 11 A, then heater, high limit and flow switch are OK. If current stays at ~ 1.5-2 A, then heater, high limit or flow switch are faulty. If water level switch (f1) has failed (opened), display will show fault code ?4″ and unit will continually fill and drain where testing won?t be completed. If flow switch (e5) has failed (opened), display will show ?0″, water won?t heat (to 150?F) and water won?t stop circulating. If NTC probe (f2/f4) has failed (opened), display will show fault code ?8″ immediately and testing will end shortly after water has started circulating.
Wont start
We walked away from it for about an hour, came back, reset it, and it started. Thank you.
10helpful
G879 Miele dishwasher does not startup
I found the solution by phoning Miele. You just have to reset as follows: switch on with program 2 and 3 pushed in. Then push top solo twice. Switch off and on again. The Miele is ready to go.
Top Dishwashers Experts
Mike Cairns
Mike Cairns
john h
