Blue color area growing on screen
A blue spot is being projected alng with the actual picture  (a round spot approx 1/8 the size fo the screen) and keeps growing. it's now about 1/4 the size of the screen, and we've reset everything to factory default values,  including the 2 lamps we just replaced.
thanks rp
  • rclennon Nov 29, 2007
    Sanyo PLV-WF10. thanks!
  • drmax Dec 02, 2007
    I have the 50-inch version. After a 18 months or so, we noticed a large vertical blue streak in the upper right corner which became increasingly noticeable and large. Was told the problem is in a circuit board which cost 2000.00 to replace and was told how the problem would progress. Description of progression was accurate, as I now have blue dots across half the screen in dark areas of picture and some additional vertical and blue lines across the screen.
    I suspect the only two viable alternatives to living with the problems until I can't stand it any longer are: replace the set or find a similar set with a broken front picture panel but is electronically sound. Would be interested in the latter.
For any of you experiencing blue dots, lines, growing blobs see the following link:
Posted on Dec 04, 2007
  • katman AZ Dec 04, 2007
    Sony KDF 60XS955 ,Check Sony's website and as I understand this is a problem that has happenned with not just Sony but other brands as well. Google your make and model with the problem, such as blue blob or green blob. Hope this helps.
  • 179 Answers
What brand and model set do you have?
Posted on Nov 29, 2007
Blue spots on Sony WEGA KDF60XS955
Thats caused by a bad optical block. The cost of that repair will almost always be greater than replacing the TV.Thats a very common issue with alot of Sony DLP models which suffered that optical block issue with the blobs of color usually blue or green
Dec 10, 2012 | Sony Grand WEGA KF50WE610 50" Rear...
Screen problems on a sony 60" widescreen tv
if some area of the screen even with the color set at zero is green go to an unused video input and look---this model is well known for red green or blue discoloration of what appears to to be the screen but is actually the optical light engine which projects the picture into a mirror which projects it on the screen.
attached is a typical light engine, note the round lens to the left , that is the optical unit that projects the picture into the mirror at the rear of the set which puts it on the screen----the engine is the most expensive part in the set so, .........
Dec 08, 2012 | Sony Grand WEGA KF60WE610 60" Rear...
Spot in center of screen, if the color pictureis black the spot is blue, if the picture is white the spot is yellow.
Spots in screen is commonly caused by defective LCD on the optical assembly. LCD replacement is very difficult. I suggest to contact the nearest service center at your area.
Oct 09, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
My rear projection TV has color spots in the picture, most noticeable on light color picture
What is the make and model of TV. If it is a Panasonic that has different colored spots such as pink, blue etc. Then you need t6o contact Panasonic as this is a memory reset that they have to perform on the LCD driver board. Other brands of LCD projection sets that have spots that appear all over the screen mostly on white back rounds are almost always dust that has settled on the LCD panels. This requires a technician to clean the LCD panels if possible.
Dec 17, 2009 | Hitachi Televison & Video
Blue section (corner) and blue dots
This set has no internal manual adjustments for color. The Tracking or B&W balance is accessed via the service menu. I don't suggest you attempt to adjust without instrumentation. the trouble with your set is not an adjustment. Most likely the Optics are at fault. This model has had issues with filters in the optics being destroyed over time by the lamp. The blue haze will get worse and continue to grow over the whole picture. The only option is to remove the Optics (light engine) and sent it out to be rebuilt.
Apr 14, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Mistubishi WD-52527 52" LCD Projection TV
those are going to be dust spots on the LCD panels internal to the optical engine. i suggest that you take the screen off and take off the panel i nthe middle of the tv with 2 screws in it and there will be an area that has 3 metal fins covering thin orange ribbon cables. the 3 square objects at the end of those ribbon cables will be the LCD panels spray wiht air compressor unitl clean and that should greatly help your problem.
Feb 16, 2008 | Mitsubishi WD52527 52" Projection HDTV
Dark spot on the top of the screen
May you should have a replacement for that, seems is has a factory damage on it!
Apr 05, 2007 | Philips 51PW9303 51" Rear Projection...
Screen spot
Since you have a black spot,you need to look at the mirror or inside screen. If it were a certain color, like purple or yellow, for instance, I would suggest a lens or picture tube, but, since it is black in one spot, I would suspect debris in those areas.
Dec 12, 2006 | Toshiba 51H84 51" Rear Projection...
Blue spot in picture
ADVERTISEMENT/SOLICITATION FROM AN ATTORNEY REGARDING A LEGAL ACTION AGAINST ZENITH/LG If you are interested in speaking with an attorney and/or joining a class action lawsuit concerning the blue haze problem on Zenith and LG rear projection LCD televisions, please contact Daniel E. Sobelsohn by phone or email: Daniel E. Sobelsohn, Esq. The Sobelsohn Law Firm 1901 Avenue of the Stars 2nd Floor Los Angeles, CA 90067 direct dial telephone (310) 461-1333 facsimile (310)861-5205
Sep 01, 2006 | Zenith E44W46LCD 44" Rear Projection...
Televison & Video Logo
484 people viewed this question
Top Televison & Video Experts
