Question about Toshiba 32HL95 32 in. LCD TV/HD Combo
No sound on digital channels
The analog channels come in with a nice picture and sound, but as soon as I go to a digital or HD channel, I have a great picture, good signal strength, but no sound. Any ideas or setting changes?
  • Anonymous Apr 05, 2008
    no sound on digital channels only...
  • Anonymous Nov 28, 2008
    It worked thanks, it was dirving me nuts, it wasnt in the trouble shooting guide. Should have looked here first.
Reset the unit . Switch off, pull the power plug of the wall receptacle and wait for about 1 min. Then plug it back in and problem will resolve. Check if you have the latest version of firmware
Posted on Jul 28, 2008
Magnavox tv converter box some channels have no sound
When you program your HD converter, it searches for all available channels in your area and you may find, as I have, channels you never knew existed. As for the audio problem, some of the found channels may be so weak that all you get is the picture - no sound. You can delete the problem channels but they are likely to pop up again on your next programming run.
Feb 03, 2013 | Insignia Digital-to-Analog Converter for...
With my Sony Bravia 46" xbr the screen keeps cutting out. I'm usig hdmi cables and can't find a reason why te tv keeps cutting out. The sound still remains but picture doesn't. Not even out technician can...
Usually this happens to my set when I am in HD cable channel mode after being on a non-digital ANALOG channel.
I basically reset the TV by changing to a DIGITAL cable channel -- stay on that channel for ten-twenty seconds -- then I switch back DIRECTLY to a HD channel (key in channel number directly on remote).
TV works fine -- seems to be a glitch when the TV changes modes from Analog to HD
Jun 29, 2010 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
Receiving the sound but no picture on digital TV channels
If you are trying to watch HD TV through the tv and you are only getting sound, it is most likely because you would need an High Definition cable box. Hope it helps
Aug 11, 2009 | Samsung HP-S4253 Television
My picture is not good. I'm hooked up to digital
to get best picture and sound you need to use HDMI connection. This is normally if you have a HD cable box. If you don't have a HD box, use the coax connection directly from the cable line. On your TV, hit the menu button, use the arrow up/down to select manual channel search, select cable and hit enter. this will scan all the digital and analog channels.
Jun 16, 2009 | Sanyo Televison & Video
No digital channels
This TV is not able to understand digital channels because its tuner is not able to find that band, it works only in analog channels. To be able to get HD channels is needed a decoder box that has digital tuner build in. for a tv to understand HD Channels with analog tuner is to us to try to speak at the same time different languages.
Mar 16, 2009 | RCA HD52W56 52" Rear Projection HDTV
No sound when watching freeview on Samsung 32" LCD TV
I`ve got the same problem, sound with analog but not digital?
Dec 12, 2007 | Televison & Video
HDTV Cable box conflict
This set does not support 480I in the DTV mode, only 480P and 1080I is supported. Try setting the analog setting in the cable box to 480p and that should take care of watching the set in DTV. Most cable boxes have a setting for format changes in the customer menu, depending on the type of box. If you are able to change the format, then the other inputs will not work since they need a 480I signal, as well as VCRs. Another setup could be to use the S-Video cable or Video input jacks to get a better picture in 480I instead of using the cable input. However, when changing from HD to Analog, you will have to change to the correct input on the set as well. Hope this helps.
Dec 24, 2006 | Samsung HCJ655W TV
Toshiba 32HL95 32 in. LCD TV/HD Combo Logo
158 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
