I have IBM Lotus Organizer 6 operating in a Windows 10 environment. How do I change the time format to a 24 hour system?
Ms, answers this 1million times there
if googling this same things
here we go
w10 time format 24hr.
omg 2nd hit.
https://answers.microsoft.com/en-us/windows/forum/all/how-do-i-change-to-24-hour-time-in-windows-10-home/1a43c1d4-f4ea-47d3-99db-95dd86489bc7
the newer w10 is changed
the h must be changed to H = 24hoiurs.
big H , not lower case.
SOURCE: 24 hour-12 hour time
Press Set - hold (top Left button) -When the sec start flashing go to the bottom left button press it 3 times -When the hour flashes press the bottom right button 1 time -Press the top left 1 once with
SOURCE: Timex Indiglo WR 30M
NOTE: 12/24 HOUR TIME IS SELECTED BY PRESSING RESET/LIGHT ONLY WHEN THE HOURS MARKER IS
FLASHING. THE “A” OR “P” WILL DISAPPEAR WHEN THE
WATCH IS SET TO 24-HOUR TIME.
SOURCE: change the time setting from 24 hour to 12 hour AM PM
Check this
Go to start>settings
Go to the system tab and the regional settings icon
Go to the time tab and it should be hh:mm:ss tt for 24 hour clock
Let me know how that works out for you
SOURCE: how to change from 24 hour to 12 hour on g shock
http://world.casio.com/wat/download/en/manual/
Use the four numbers on the back of your watch and you will have a PDF version of your instruction manual.
Hope this tip helps
R/
David
SOURCE: How do I change my Casio twin sensor alti thermo
Press and hold the top left button for 2 seconds to go into the time adjustment mode.
While you are in this mode press the top right button to switch between 12 hour and 24 hour modes.
Press top left to return to normal.
