Question about Zanussi F1045W Front Load Washer
Kenmore model #110.22802100 drains but no spin
This is a top load and direct drive washer. I am trying to fix it for my brother. There are no noises when selecter hits the spin cycle position. Washer drains properly just no spin. Can you eliminate possibilities and give a direction to start troubleshooting? I woul like to narrow it down to a few things before I get started.
Thank You
-Tyler
  • GETRFIXED Dec 12, 2007
    watugot,
    Thank you for your tips. I had actually found the clutch to be slipping and replaced it. These things are so easy to work on! My brother and his wife got a very nice washer for their apartment for Christmas.
    Happy Holidays
  • 290 Answers
If it is draining, then the motor is ok.
If it is agitating properly, then the motor coupler is ok.
This leaves the gearcase, clutch, basketdrive(brake), basket drive block, or timer.
Raise the lid and hold the lid switch down. Start a rinse cycle and let it go through the cycle. It should drain the water, then stop the motor for a split second then kick the motor back in and start spinning. If it doesn't drop out that split second then the timer is holding it in neutral drain. You can recreate this by letting it start draining, then let off the lid switch, then depressing it again. The basket should start spinning. If not,
Raise the lid and hold the lid switch closed. Start it in spin and see if you can get it started spinning by hand. If so you probably have a slipping clutch.
Post back with any questions.
You can go to sears.com, click on parts, and enter your model number and see parts diagrams of the washer. This can be helpful.
Posted on Nov 26, 2007
  • Michael  Lindley
    Michael Lindley Nov 30, 2007
    Tyler
    Just wanted to follow up and see if you got washer problem figured out.
    Thanks/Mike
Hi. I have a similar problem and was wondering if you guys might be able to help me. Everything works ok but when it's finishing the spin cycle, it makes a loud rumbling noise. The rest of the spin cycle works ok. I think it might either be a part of the clutch or brake assembly that is bad. Any input or suggestions would be very helpful.
Thanks
Posted on Jul 29, 2008
Our Kenmore top load model 22422 started having problems with the spin cycle. Once it gets to the spin cycle, it makes a terrible grinding like noise - it is not spinning. However it will drain if you let...
The double shaft motor does double duty. One direction for wash and another direction for spin. In wash mode the water stays put in the tub because the pump is running backwards. In spin mode the motors turns in opposite direction. This pumps the water out and spins the clothes dry. From what you have described the drive coupler is toast.
This video shows how to swap the drive couple out:
More HERE
Mar 01, 2011 | Kenmore 22422 Top Load Washer
Top load 80 when spin is complete and drum noise
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
KENMORE top load, direct drive, neutral drain washers are made by Whirlpool.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Assuming that the springs are OK and that the vibration pads are in place and not worn, (See the Sears diagram or the following Whirlpool Service manual)
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
the problem points to the brake.
The washer uses a brake system to stop the basket at the end of the spin cycle.
Just like a brake on a car, it's designed to slip a bit so that the basket / car doesn't come to an abrupt halt.
Over time, the brake shoes can jam against the brake drum and bring the basket to a halt too quickly with a lot of noise.
A way to solve this (that I tried and it works) is to pull the basket tube / brake assembly and if the brake shoes look OK, spray a small amount of silicone spray on the inside of the brake drum.
Following is a description of how to remove the cabinet, pump, motor, transmission and basket drive tube on Whirlpool / Kenmore / Roper direct drive washers.
As an aside, you don't need a special spanner wrench to remove the spanner nut. I've found that a short (10") pipe wrench hooked over one of the spanner nut tabs and tapped with a hammer will usually loosen the nut. Also, rather than hitting the Drive block directly with a hammer, put a short piece of wood under it first to protect it.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
Following are the Whirlpool Service manual for this type of washer and the Whirlpool parts list for their commercial washers although the consumer models are basically the same. Whirlpool (and Sears) have replacement brake pad / spring sets.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
May 12, 2010 | Kenmore 24032\24036 Top Load Washer
I have a top loading kenmore washer. It is making a load noise on draining. Probably something at my pump filter, I guess. but how do I get there to look???
See the following illustrated description of how to access the pump on these washers.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=134&osCsid=516937a95eebc772fcc85c8de447bd5b
Dec 15, 2009 | Kenmore Washing Machines
Washer will not spin or agitate. Pump works.
First, see the following Whirlpool Kenmore installation and service manual for top load, direct drive washers.
If it drains and you can hear the motor trying to turn the transmission for the agitate mode, the obvious first answer is the Motor coupler. I'd replace it just to be sure.
If it's not the Coupler, the problem points to the transmission itself.
There are only two components of the gearcase that are used for both agitating and spinning.
One is the Agitator shaft which drives the agitator and holds the spin pinion that drives the clutch for spinning.
The other is the main "Bottom and pinion gearcase" itself.
Please see the following Whirlpool parts list for commercial top load direct drive washers although the consumer models use the same transmission parts.
Oct 24, 2009 | Kenmore Washing Machines
Water wont drain out of washer
If the washer will agitate and spin but won't drain, the problem points to the pump.
See the following for how to remove the pump on top load, direct drive washers.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=134&osCsid=54a38ed7736cb193900d050b98aa7947
Check the discharge hoses and see if there is an obstruction in the pump itself.
Oct 16, 2009 | Kenmore 24032\24036 Top Load Washer
I have a Kenmore 80 series washing machine and the spin cylcle isn't working. There is a loud grinding noise during the spin cycle and the tub doesn't spin.
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
This also assumes that:
1. The machine will agitate and go through the rest of the cycles.
2. It will pump out the water.
3. Since it tries to spin, the Lid Switch is OK.
The problem points to the clutch and / or transmission
See the following for how to pull the clutch on Kenmore top load direct drive washers.
If the clutch springs and pads seem OK, the problem points to the main spin gear inside of the transmission. If the clutch springs and/or pads are damaged, there is a rebuild kit for them.
Following is the Whirlpool / Kenmore installation and maintenance PDF on how their top load, direct drive, neutral drain washers work.
Here is another PDF of the Whirlpool parts list for their commercial washers, consumer models are basically the same.
If you look at the operation PDF you'll see how the transmission works when going into the spin cycle. If the "Neutral Drain" cams are intact, they drive the main spin gear which drives the spin gear connected to the clutch.
If the main spin gear is broken (It's a metal plate surrounded by plastic gears) you would hear a major grinding noise and the washer wouldn't spin.
Opening the transmission is not difficult but is a messy job. It holds about 14Oz. of oil.
Pull the transmission, remove the clutch (there is a spring clip that holds the clutch on the main agitator shaft, remove the 8 screws carefully the transmission holds 14Oz of oil, remove the clip holding the main spin gear on and check the plastic cams.
If the main spin gear or neutral drain assembly cams are damaged, they aren't too difficult to replace.
The Whirlpool Parts PDF has part numbers for both.
The Neutral drain assembly costs about $15 which is a lot less than $170 for a new transmission.
The Main spin gear is quite a bit more but still less than a transmission.
Oct 12, 2009 | Kenmore 24032\24036 Top Load Washer
Top load washer making horrible grinding noise when pumping out water
If everything else works fine, agitate, spin etc. it seems as if something may be stuck in the pump.
Following is a description of how to remove the cabinet and pump for top load direct drive washers.
I;d pull the pump (be prepared to catch the water that is in the hoses) remove the hoses from it and check to see if something is stuck inside of it.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=134&osCsid=0724eb6fa1a6157c5a788828bb6d653b
How do i expose the inner tub and moving parts to check the source of a loud noise on spin cycle
See the following for removing the cabinet.
The loud noise could be the Motor Coupler between the motor and gearcase or the agitate gear in the transmission / gearcase.
If your washer is the basic Whirlpool / Kenmore top load direct drive, see the following for the operation and maintenance of the washer.
Sep 30, 2009 | Kenmore Washing Machines
Kenmore Model 925 75 110 washing machine makes loud noises when the spinning cycle ends (as it stops spinning). Any ideas? Ease of repair ?
There is also an excellent PDF document from Whirlpool describing how Direct Drive washers work.
We has the same basic problem with a Kenmore direct drive washer. At the end of the spin cycle we heard a loud noise as the brake stopped the drum from spinning.
Sometimes, what can happen is that the brake will grab the brake drum, like a brake on a car suddenly locking a wheel.
The brake is supposed to slow down and stop the drum without locking.
We were able to spray a small amount of silicone spray inside the brake drum, which allowed the shoes to more gently grab the drum.
See GURU JSROCK516 Description of how to remove cabinet and access the transmission. http://www.fixya.com/support/r699497-replacing_gearcase
Remove the cabinet and look at the drum directly above the silver colored clutch assembly.
Using an spray can of silicone spray, and a directional tube, spray a very small amount into the brake drum.
Sep 25, 2009 | Kenmore 22422 Top Load Washer
Kenmore 90 series noise after spin
You need to replace the drive block and basket drive. You can download a tutorial to get you started at www.shop.washermd.com. The gearcase replacement tutorial will put you in the right direction. Dave
Mar 01, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Zanussi F1045W Front Load Washer Logo
314 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
