SOURCE: set lamp timer
Jerico, If you will go on dlp lamps .com I believe they answer that question in their FAQ. You can also give them a call. Look on their site for number. All I know is that they make the whole process really easy.
SOURCE: Lamp hour reset
I don't thing that because you were not reset the time lamp used now your LCD projector stop function
What was exact the unit did? no power at all or some LED light up or flashing. In any case to reset the lamp time use you must enter when unit is on
As you mentioned you did replaced the new lamp, You should check again if you reinstalled properly the lamp and lamp cover because under the lamp cover it had a safety switch if this SW not active then the unit will be in protection mode
I sugges you to remove again the lamp and reinsert properly and secure the lamp cover and try it again and if it still is not go then let me know what are the status of the 2 LED
Cheers
SOURCE: Panasonic projector PT-L78 lamp reset
Press the MENU button. Use the < > arrows to get to the OPTION menu. Press the ENTER button. Select LAMP RUN TIME. Press and hold the ENTER button for about 3 seconds. The 'lamp time reset' will display. Press OK and press the ENTER button. This will reset the lamp hours as well as turn off the projector.
SOURCE: Horrible burning smell from lamp
If you ordered it directly from sony then i would be concerned and contact the to have it replaced under warranty. If you did not get it directly from sony I would expect it is a rebuilt lamp or you purchased just the lamp part instead of the whole cartridge and installed it into the carttridge yourself. The lamp is designed to be replaced as a cartridge . The smell is probly a lamp that is burning the wires on the back side of the lamp because it is incorrectly inserted and the wires are touching the glass. Just a couple times i have seen a lamp that will smell slightly as the plastic and insulation heats up for the first time.But it only smells a little for like a day.
SOURCE: After just recently replacing the bulb I am
Here is proceudre to reset lamp timer in your TV..
While pressing the VOL Down button on the projection display, hold down the PIP or SPLIT button on the remote control at same time for more than 5 seconds.
When reset procedure is complete, the screen message ' lamp time was reset to 0' will appear.
Hope this info will help you.
Thanks.
Replace the lamp cover and front panel, if necessary. Plug your TV back into the electrical outlet and power it on.
You probably bought a lamp from discount merchants. They use bad connectors that melt inside. Try and remove the lamp. If it is stuck, that is the issue(melted connector). It is repairable but may not be cost effective.
