Question about Brother Multi-Function Center® MFC-215C All-In-One InkJet Printer
Brother MFC-215c Continuous Paper Jams (Bad/Dirty Paper Sensor)
Installed a continuous ink-flow system on this printer and had a few teething troubles that I've now resolved, but have a problem where there was too much ink getting to the print head.
Cleaned up the excess ink everywhere but on what I assume is the paper sensor attached to the print head and now even though paper is being fed to the right place the printer is not seeing it.
How can I clean this sensor? I haven't been able to figure out how to get at this.
Thanks in advance.
  • 832 Answers
Open the printhead cover carefully. You have to pull up the mini circiut board inside. Here you can clean the sensor.
Posted on Nov 25, 2007
Paper jams brother mfc 7420
Paper Jams are routinely caused by bad roller in the printer. The Heat of laser printers can render these rubber roller pretty useless in a couple of years or less if you print often. If you have recently replaced the drum (according to the recommended print output number), Then If an $80 dollar roller + labor is worth it to you, go for it, otherwise buy a new printer and Brother gives the best ink value per page. hope this helps.
Jan 28, 2013 | Brother MFC 7420 All-In-One Laser Printer
My printer: brother model mfc 215c is not working.
Brother model MFC-215C is not working. It says: cleaninig impossible. Try trouble shooting and routine maintenanace. What can I do to solve this problem?
Jul 26, 2010 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC - 215C Unable to clean, my home doesn't use actual ink tank for Brother, so when every time the ink is less, or almost finish i need to clean it, to **** to ink in. But this time I can't clean,...
The machine has a mechanical problem or a foregn obstacle, such as ripped paper.
unplug electric cord and power on with your finger on MENU button, till you see "MAINTENANCE"
on screen, then release MENU button and dial 82
so you see something like
"machine error" and 2 digits of error code
if there is 46 error code if have to replace the ink absorber box and reset the purge counter to zero.
which error there is?
Jun 20, 2010 | Brother Multi-Function Center® MFC-215C...
Brother mfc-215c unable to clean?
The ink blotter in the bottom of the machine is full, this is a built-in redundancy. Machine needs to be completely stripped to replace this.
Buy another brand next time.
Oct 01, 2008 | Brother Multi-Function Center® MFC-215C...
Brother mfc-215c how do i let the printer know ive changed the ink
take out the printer cartige and clean it with a wet alcohol cloth and make sure no ink clots on it.
place it properly in the cartige holder.
Jun 02, 2008 | Brother Multi-Function Center® MFC-215C...
@artkoy:
There is no Error 10 within the maintenance of the printer!
An error starting with 10 (and two more digits) belongs to the communication device (fax).
Plz check again what two digit error you have and post again.
@peter:
you need a new waist ink absorber. plz check the forum for unable to clean or error 46. Its explained many times.
Mar 27, 2008 | Brother Multi-Function Center® MFC-215C...
Brother Multi-Function Center® MFC-215C All-In-One InkJet Printer Logo
145 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
