Question about PC Desktops
HP PSC 2355 all-in-one printer problem
The error paperjam comes on with the paper half way in the printer..when I press OK the paper feeds out without printing(no jam!)
I have clean the rollers with the back remove and also the feed rollers.
someone told me it may be the sensor is corrupt
what else can I do.
    Problem Solver:
  • 13 Answers
Re: HP PSC 2355 all-in-one printer problem
Try this:- go to device manager uninstal driver of your printer an restart your machine , now again instal driver of the printer by going to add printer manu.
if this does not solve your problem then try changing your toner/cartridge
Posted on Nov 26, 2007
0 characters
3 Points
Hi i have a casio TE-100 it will let me program the date in and wont let me go any further, i have turned the key to reg put a $2.00 sale in and then it wont let me go any further it is freezing. I press...
Hi Kristy. I have a large amount of experience with them so you've come to the right place.
Firstly, a few questions. Does the machine print any error codes on the display or paper (especially when you get it going by plugging back in)?
Also, once you get it working again, just try pressing feed without touching any other buttons. Can you get the paper to feed at all?
Aug 23, 2013 | Casio Parts Cash Register PC Desktop
My HP printer is not feeding paper.
Here is the solution for your problem just go through the steps given below and you can fix it yourself.
1. Check to make sure your printer has paper in its paper tray. If your printer has paper, check to make sure that the tray is not overloaded. If you suspect your paper tray is overloaded, remove some paper from the tray and attempt to print again.
2. Use the same type of paper when stocking the tray with paper; do not mix different types of paper into a single stack. Mixing different brands and weights of paper in a single stack makes your printer more prone to paper feed problems. If you find that one particular type of paper causes consistent feed problems, switching to a different type or weight of paper may solve the problem.
3. Check to make sure the paper in the tray is whole. Torn and creased paper will cause problems with the printer.
4. Open your printer's rear access cover and inspect the paper feed rollers. Dusty or dirty rollers cannot grip the paper; clean them with a soft, damp cloth and water.
5. Count your printer's rollers. HP printers have six paper feed rollers; if your printer is missing rollers the paper will not feed correctly. Contact HP to replace the rollers and repair your printer.
Oct 06, 2010 | PC Desktops
I'm having trouble with the Javelin J330i printer. When trying to print cards it doesn't pull them through correctly and then gives an error that the ribbon is broken. I have tried resetting the printer,...
check the feed tires ,the ones that feed the paper/cards into the printer. they maybe slick with paper dust. I recommend taking a cotton dish cloth or rag with some 409 cleaner on it the the feed tires clean all the paper dust off the tires let dry then try to feed card again. sound like the sensor is covered with paper dust, and is giving a false error.
Jul 09, 2009 | Javelin Systems Inc Javelin Viper PC...
No ink prints on paper
you have remove the tape cover either over the jets or the injection holes failing that try cleaning the gold coloured contacts with ipa alchohol
May 05, 2009 | PC Desktops
I have a Dell 946 printer and Im trying to print Avery 8871 business card sheets. When I press print the printer will not feed the sheet through and it says there is no paper. I tried to adjust the...
I looked up the user guide at Dell's website and looked up printing cards.
  • The print side of the cards faces down.
  • The cards are centered on the paper exit tray.
  • You select Automatic, Normal, or Photo print quality.
  • Apparently you need to feed the card stock one page at a time into the printer on TOP of the paper exit try (The card stock will feed in from above the normal paper load try [remove paper from the paper tray] and once printed come back to the same spot.
    Jan 26, 2009 | PC Desktops
    Please give me the name of a printer that WORKS with writing checks in Quicken using Windows Vista 64. My HP all in one does not - printer jams every time.
    HP will work. The jam is a paper problem not a hardware or software issue. Try line feeds without printing. HP also makes the best printer paper so don't skimp on that. Moisture in the paper is the most common paper jam problem aside from debris getting into the rollers. If line feed fails then physically inspect the whole paper path. I have Canon, Epson, Dell, HP and Lexmark printers with Quickbooks Pro. They all work. Paper is your problem barring a banana falling into the rollers. Never leave paper in a printer for a long time as it will stick to itself. Steve
    Oct 21, 2008 | PC Desktops
    HL-2140 printer: error light on: But, paper is in the tray. I have removed the tray several times and returned it. I have turned the printer on and off. THis problem occurred right after printing on the...
    pls. try to download the latest driver from your printers website and upgrade your driver. updated driver will fix the problem.
    PS, pls vote. tnx
    Sep 15, 2008 | PC Desktops
    We have a HP printer series 1310 and have recently purchased an ASUS notebook. We have attempted to install this printer to the laptop with difficulty as we continually rec've an error msg stating it is...
    The printer should be compatible with both vista and XP
    your printer is a serie 1310 but if you look closer you should find a more exakt nr like
    » HP PSC 1311 All-in-One Printer
    » HP PSC 1312 All-in-One Printer
    » HP PSC 1315 All-in-One Printer
    » HP PSC 1315v All-in-One Printer
    » HP PSC 1315xi All-in-One Printer
    » HP PSC 1317 All-in-One Printer
    » HP PSC 1318 All-in-One Printer
    or something like it. check for the serie nr or a mark somewere on the printer and you should find the right printer model.
    you can download the drivers here when you find the right model.
    good luck.
    hope I helped.
    Sep 04, 2008 | HP PC Desktops
    Everytime i turn on my hp psc 1510 printer the check paper light flashes and it half gobbles up a sheet of paper then jams. also when i open the front flap to check cartridge installation is correct the...
    clean its roller and service other part with clean cotton.
    or it may that ejector clip of printer causes this.
    when paper prints and it travel outwards then there are ejectors that pushes it out .sometimes that clips bend inside and not allow paper to come out.
    Aug 14, 2008 | HP PC Desktops
    PC Desktops Logo
    61 people viewed this question
    Top PC Desktops Experts
    Brian Sullivan
    Brian Sullivan
    Are you a PC Desktop Expert? Answer questions, earn points and help others
