Question about KitchenAid 31 in. KGCS105 Gas Cooktop
Gas cooktop problems
When i turn one burner on,it lights with no problem , and when all the others in off position , the other burners seem like they try to ignite , with the clicking and little spark please help dont know whats going on
  • 1 more comment
  • KennyG961 Jan 27, 2008
    The ignitors on my DCS six-burner unit do the same thing: They continue to click in harmony even after the desired burner is lit, but, interestingly, only if the flame on the lit burner is set below a certain low level. We frequently have to cook at much higher burner setting than needed just stop the annoying clicking.
    I replaced the spark module, but this did not solve the problem. Any other suggestions? Thanks
  • Jeanne50 Mar 12, 2008
    I've had intermittent igniter sparking/clicking even when the burners are off but always resolved within minues by turning burner on for awhile. Today I have all 4 burners cliclkng and its driving me crazy. What's a temporary fix?
  • Dianaq May 11, 2010
    I need to replace the ignitor switch in my KitchenAid model kgct365x. I have ordered the part and have it. How is the best way to replace it? Is it possible to do you do it through the knob hole? if I have to lift the glass top, how the best way to go about that?
  • 213 Answers
There is a part in the cooktop called a spark modual. it controls all the ignitors when it goes bad that what it does. replace the modual to fix the problem
Posted on Nov 25, 2007
    Director Badge:
    Uploaded 100 video answers.
  • KitchenAid Master
  • 488 Answers
this video shows how to replace all parts in your cooktop as well as spark module
Posted on Oct 16, 2014
I have a gas glass cook top (JGC9536) with a problem at the right front surface burner (12,500 btu). I used to be able to just turn the switch on high and the burner would light. Now, there is spark and...
Make sure there is no blockage of the burner near where the spark jumps. All it takes is a drop of water to stop the gas flow near the spark. Most likely you can use a knife or some other thin blade to clear the slots where the flame comes out of the burner.
Feb 20, 2014 | Jenn-Air 35 in. JGC9536 Gas Cooktop
The igniter on the left front burner of the
YOU HAVE a shorted ign sw. some of these only came in a wire harnes of 4 . and if they don't change all four when in there .. mm hope this helped .. feed back pls ..
Jul 20, 2010 | Amana AKS3040 Gas Cooktop
Electronic igniters will not turn off when the gas burner lites. all four igniters run untill you turn off the nob or unplug the unit
I'm dealing with this same problem. This cooktop has a dedicated simmer burner which is the only thing going on the lowest setting. This simmer burner seems to be how the igniter senses that it can stop. If it doesn't light, the igniter keeps clicking. Usually cleaning the burner will solve this. You may need to unscrew the nut holding the lower piece of the burner in place in order to clean it up.
Apr 17, 2010 | DCS 36 in. CTD365N / CTD365L Gas Cooktop
I have a jenn-air sealed gas cooktop jcg8430 only 1 burner lights
you have a problem with the ht leads or spark electrodes
Aug 18, 2009 | Jenn-Air Cooktops
Jenn-Air 36 Gas Cooktop
try to use macth in the burner u said,if ok the flame,the problem is the igniter wire,nid to replace,but if u use the macth then the flame is malfunction again i think the sensor is the problem,nid the tecnician coz is hard to repair,sometime after repair the sensor it problem again in next day
tnx gerbee
Jul 02, 2009 | Jenn-Air 36 in. CCGP2720P Gas Cooktop
One burner on a 6-burner gas cooktop misbehaving
sounds like the air /gas mixture is off.look at where the burner meets the gas valve (the knob) under the grates and play with the adjuster turn it slowly while the burner is on and this will change the value of the air/gas mixture good luck
Jan 25, 2009 | Bosch 30 in. NGP 732 / 736 Gas Cooktop
Gas burner not lighting
make sure the burner ports are not clogged. and the caps are properly positioned. clean ports with a wire or a straightened paper clip if clogged.
make sure the igniters are clean and dry
Aug 03, 2008 | Thermador 31 in. SGS304Z Gas Cooktop
Electronic ignition
Most likely you got water (or some other liquid) into the control knobs. Unplug, go to bed and try it again in the morning. If you continue to futz with it, you run the chance of burning out the electronics in the control knob, like I did. :(
Oct 22, 2007 | Miele 35 in. KM326G Gas Cooktop
KitchenAid 31 in. KGCS105 Gas Cooktop Logo
266 people viewed this question
Top KitchenAid Cooktops Experts
Dale Copeland
Dale Copeland
Are you a KitchenAid Cooktop Expert? Answer questions, earn points and help others
