Its a fuser code. To reset it the code and to get it work again. Follow these steps:1) Turn the main power off ( the switch behind the toner door )2) Hold down the Utility button while you turn the machine back on. Jul 12, 2017
PrintCopy .info
https://printcopy.info > code=C3423
Code: C3423 · Description: Fusing heaters trouble (pressurizing side) · Remedy: 1 Check the fusing unit for correct installation (whether it is secured in ...
Why The Dell Printer Offline Error Occurs?
§There can be issues with Printers and Devices in the control panel thereby leading to the problem at hand.
§There can be issues with the Printer Settings resulting in the particular error.
§Issues with the Printer Driver can also cause this Dell-related error code.
§There can be some connectivity issues with your Router or Modem that are probable causes of the Printer Offline error code.
For more info Do Visit Us: Dell Printer Offline
that is GOOD did you touch the trouble reset, yes then power off and turn on should be go to code if the code comes back then replace the the code does not exsit in the service manual what is the code C-34??????
if after this procedure code come back replace the fuser, attempt again machine my catch on fire that would ruin a perfectly good day
1. Turn OFF the main power switch. 2. Turn main power switch ON while pressing the Utility/Counter key. 3. Touch [Trouble Reset]. 4. Check to make sure that [OK] is displayed and the it has been reset. 5. After turning off the main power switch, turn it on again more than 10 seconds after and
check if the machine starts correctly.
Its a fuser code. To reset it the code and get it to work again.
1)Turn the main power off ( the switch behind the toner door )
2)Hold down the Utility button while you turn the machine back on.
3)Keep holding till you see "Trouble reset"
4) Push trouble reset then turn off and on the machine and will start working
