Look for a ryobi distributor or online search for part using make and model
Try Bunnings, they are the Agents for Ryobi
Yes check Parts tree.com
SOURCE: dented rear bumper, how does bumper detach to pound out?
is it a rubber bumper? use suction cups, thats what dent specialist use instead of takin off the entire bumper. use a winshield dashboard suction cup for example. Just be creative...
SOURCE: replacing front bumper on 1999 buick regal
7/16th or 10mm Sheetmetal nuts All over Behind the Bumper Thak Bumper off first
SOURCE: Bumper cover removal
It is a little more complicated than that. There are two nuts below the headlight assemblies in the engine compartment. You will need to remove the battery and overflow bottle to get at the one on the passenger side. Remove the turn signals in the bumper, then there are 2 or 3 bolts holding a mounting bracket behind the each of the turn signals. There are a number of bolts with washer heads and reatiners on the underside of the bumper as the previous responder indicated.
SOURCE: How to Remove the Rear Bumper - BA Fairmont/Falcon
Firstly, you need to remove the rear splash shields from within the rear wheel arches and also the tail lights. Then remove the scrivets from the lover edge of the bar. Next remove the scuff plate at the boot opening and fold the carpet back. There are four nuts which hold the bar on, undo these and then lift the sides of the bar up and pull out. The bar has large clips on the side which hold it in place.
SOURCE: 2000 Daewoo. Lanos won't start. What are the cam shaft positions
both lobes on number 4 cylinder face each other (point towards centre of engine)when timming marks on cam gears are lined up
