HP Officejet 6310 All-In-One InkJet Printer Logo
Posted on Aug 03, 2009
Hp 6310 problem is insert cartridge on left - HP Officejet 6310 All-In-One InkJet Printer
Rakesh Kumar
Level 1:
  • Contributor 296 Answers
  • Posted on Aug 03, 2009
Rakesh Kumar
Contributor
Level 1:
Answers
296
Questions
0
Helped
98429
Points
14
Hi, First of all remove the cartridge and clean the connectors. You might have ink on the connectors. See if it fixes your problem.
Thanks! mannu_rakesh
4 Related Answers
Anonymous
  • 2120 Answers
  • Posted on Jan 31, 2009
SOURCE: ink level monitoring on officejet 6310
Yes. Never refill or buy refilled ink carts.
A
Anonymous
  • Posted on Sep 22, 2008
SOURCE: hp 6310 Cartridge error
Removed Color Cartridge and allows to print in gray scale and fax. Set default printing to gray scale
Anonymous
  • 2049 Answers
  • Posted on Nov 16, 2009
SOURCE: I have an HP Officejet 6310 All-in-One printer. I
Open the HP Photosmart Software on a Windows computer
1. Do one of the following:
– On the Windows desktop, double-click the HP Solution Center icon.
– In the system tray at the far right of the Windows taskbar, double-click the
HP Digital Imaging Monitor icon.
– On the taskbar, click Start, point to Programs or All Programs, select HP,
and then click HP Solution Center.
2. If you have more than one HP device installed, select the HP All-in-One tab.
Note On a Windows computer, the features available in the HP Solution
Center vary depending on the devices you have installed. The HP Solution
Center is customized to display icons associated with the selected device. If
the selected device is not equipped with a particular feature, then the icon for
that feature does not display in the HP Solution Center.
From here, you can scan, make copies, and perform maintenance procedures such as checking the ink levels for the print cartridges.
Testimonial: "I'm sorry. I forgot to say that I have a Dell computer, not an HP, just an HP printer. Very stupid on my part not to include such important info."
Anonymous
  • 776 Answers
  • Posted on Sep 03, 2010
SOURCE: How can I see how
Please read the below mentioned article for detailed information:
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=110&prodSeriesId=1120059&prodTypeId=18972&prodSeriesId=1120059&objectID=c00634261
Check Step 3
How do I insert One Black and one color cartridge ? I have hp 6310 OFfice jet All in one. Thanks.
Lift the whole of the scanner section and you can get at the twin ink cartridges. The two Vivera ink cartridges, one for black and the other tri-colour, clip into their carriers and apart from loading paper, that's the only physical installation required. No, for color cartridge 344 and black 339 cartridge.
My printer won't print..
After inserting the new cartridge, we have to align the cartridges, so please perform the steps in given below link:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00609415&cc=us&lc=en&dlc=en&product=1119598
17helpful
3answers
How to reset hp 6310 printer
The below are the 4 Types of Resets.
Power Drain
  • Turn OFF the printer, disconnect the power cable from backside of the printer and from wall outlet.
  • Press and hold the Power button for 60 seconds.
  • Connect the cable and turn ON the printer.
Partial Reset
  • Remove the power cable from back side of the printer while its ON.
  • Press and hold "#" and "3" button, while holding them both insert the power cable and release the button after 10 seconds.
  • If printer turns OFF, press power button to turn it ON.
Semi-Full reset
  • Remove the ink cartridges.
  • Press and hold "#" and "6" button, while holding them both insert the power cable and release the button after 10 seconds.
  • Insert the ink cartridges.
Full-NVM Reset:
  • Press and hold "OK" and "Cancel" button, while holding them both insert the power cable and release the button after 10 seconds.
Regards,
Rizwan
Cartridge error - printer doesn't recognise cartridge inserted.
Normal 0 Could have a corrupt driver.
Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Ink Cartridge problem
The 6310 takes a #95 tri-color cartridge. #901 is for Officejet 4500 and 4600 series printers.
Cartridge erro
hi,
try to clean the printer contacts of the left.before you do that unplug the powercable first.used a cotton swab to clean the copper contact of the printer..after cleaning insert the ink cartridge..if the error is still occuring this is now an issue of the printer..the printer needs to be replaced/serviced...
Cartridge error
try to clean the copper contacts of the printer in the left.before you clean the contacts unplug first the power cable..after clean the copper contact go ahead and insert the ink cartridge..if the issue still remain/occur the printer needs to be repaired/replaced...coz it is now a hardware issue
k24674
Grand Canyon Tech
Grand Canyon Tech
