Cameras Logo
How to find use by date of Muralex B/N P863504
During setup an incorrect year and time entered. how do I reset them
Setting the date and time in Windows 10
Note: Windows 10 automatically adjusts your date and time for you and only allows you to adjust the time if you disable this feature. If the wrong date and time is being set, you may need to change your time zone, or if you want to increase or decrease the time for other reasons, follow the steps below.
Right-click or tap on the date and time in the Windows Notification Area in the bottom right corner of the screen.
Click Adjust date/time.
Make sure your Time zone is set properly if your computer is displaying the wrong time.
To manually adjust the time, turn off the Set time automatically option and then click the Change button.
Setting the date and time in Windows 8
In the lower right-hand corner of the screen, click or tap the Windows Notification Area where you see the date and time.
Select Change date and time settings... in the bottom of the window that appears (shown below).
Time and Date in Windows 8
In the Date and Time window, under the Date and Time tab, click the Change date and time... button.
Make your adjustments and click OK.
Click OK on the main Date and Time window to save the changes.
MacOS
Choose Apple menu > System Preferences, then click Date & Time.
Click Date & Time, then set the date and time automatically or manually.
Automatically: Select “Set date and time automatically,” then choose the network time server for your region.
Manually: Deselect “Set date and time automatically,” click today’s date on the calendar, drag the clock’s hands to show the correct time (or enter the time), then click Save.
Click Time Zone, then set the time zone automatically or manually.
Automatically: Select “Set time zone automatically using current location.”
Manually: Deselect “Set time zone automatically using current location,” click a location on the map, click the Closest City pop-up menu, then choose the city closest to your location.
Click Clock.
Show date and time in menu bar: Select the checkbox to see the date and time in the top-left corner of the menu bar. In “Time options” and “Date options,” set how you want the date and time to appear.
Announce the time: Select the checkbox to hear the time announced, then choose when you want it announced. If you want, you can customize the voice.
10helpful
Username and password for eset full version
TRY ONE OF THIS AND DON'T FORGET TO RATE
Username: EAV-30046840
Password: 43xm3j2aen
Expiry Date: 25.07.2010
Username: EAV-30047000
Password: mj4nmbudvk
Username: EAV-30518969
Password: m6ksru4vm6
Expiry Date: 28.07.2010
Username: EAV-30191114
Password: a5utejpdvm
Expiry Date: 29.07.2010
Username: EAV-30662248
Password: tc45mbsaex
Expiry Date: 02.08.2010
Username: EAV-30490460
Password: pv3hcjvc44
Expiry Date: 06.08.2010
Username: EAV-31499771
Password: v3te8xpasu
Expiry Date: 05.09.2010
Username: EAV-31499778
Password: u84apanjkt
Username: EAV-31502567
Password: ueee6cuctx
Username: EAV-31550064
Password: rd7fcrks3u
Expiry Date: 08.09.2010
Username: EAV-21460280
Password: k4tjae4maf
Expiry Date: 12.09.2010
2helpful
How can I change the date without turning 24 hours ?
mcdevito75 here, Most day / Date or just date watches with a stem (winder) even if they are quartz have a 2 position stem. Smply slip a fingernail under the crown and lift to it"s first position, this should allow you to change the date with haveing to go the 24 hours but remember the date cahnges at 12--1 Midnite, Best bet, change the date to the date before the date you want then go the 24 hours this way the date will change at midnite and not 12 noon.
1helpful
3answers
How do i remove the time and date at bottom right corner of picture.
Manual can be downloaded free from here ....
http://safemanuals.com/annexe_POWERSHOT%2020A550%2020CAMERA%2020USER%2020GUIDE%2020ADVANCED%2020_CANON_POWERSHOT%20A550-_E.htm
Basically the date stamp can be turned on / off as an option on the RECORD menu. Page 33 of the manual explains it (with pictures).
Note that if the option is turned on, it states that the date / time is permanently embedded in the picture.
Hope this helps
3helpful
2answers
Displaying time and date when printing
The date/time cannot be deleted once it is embedded in the image. To turn off the date/time deselect the date/time stamping by following procedure:
These instructions explain how to insert the date in images.
attention:
  • The [Date Stamp] cannot be deleted from the image data once it has been recorded because the date is written in as an image.
  • When selecting [Date Stamp] , [Recording Pixels] is set to 1600 x 1200 pixels and the compression (image quality) to [Fine].
  • When the shooting mode is set to <Movie> (g0029623.gif), settings for inserting the date and time cannot be made.
  • The following explanations are provided based on the assumption that the [Shooting Mode] is set to <Program AE> (g0034813.gif).
1. Press the <Power> button on the camera.
2. Press the <FUNC./SET> (g0046915.gif) button.
3. A screen like the one below will appear on the monitor.
Select g0013174.gif [Date Stamp] (g0013171.gif) in the [Recording Pixels] section g0013173.gif.
g0013176.gif Press the <MENU> (g0046624.gif) button.
4. A screen like the one below will appear on the monitor.
g0013173.gif Operate the <directional buttons> left or right to select [Date Stamp] and set it to [Date] or [Date & Time].
g0013174.gif Press the <MENU> (g0046624.gif) button.
5. Press the <FUNC./SET> (g0046915.gif) button.
6. Make sure that the [Date Stamp] is set and the following screen will appear with the icon (g0013164.gif) in the lower-left corner of the screen.
7. When shooting with this setting, the date will be embedded in the image as shown below.
g0013173.gif [Date]
g0013174.gif [Date & Time]
warning: The date, its font and color, and the position where it is displayed cannot be changed. Also, dates and times recorded with [Date Stamp] cannot be deleted.
If you need a manual for the A480, you can download it from:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=320&modelid=18155
Please rate this solution. Thanks.
1helpful
Converting date of a month to last working day of the month
use the below formula to get the date of the LWD (Monday thru Friday) of the month.
Assumed that if the date in cell A1 is 6-May-2005. then formula will be
=DATE(YEAR(A1),MONTH(A1)+1,0)-(MAX(0,WEEKDAY(DATE(YEAR(A1),MONTH(A1)+1,0),2)-5))
Can't get the Date off the Pictures
First you have to go to the set up menu and set the correct time and date, then you can go back to the settings and select OFF for time and date. If you do not set the correct time and date , that default date stays in the picture.
Top Cameras Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Camera Expert? Answer questions, earn points and help others
