Question about Sony Playstation 3 (PS3) Console
Video problems and controller connection
My dogs knocked my ps3 off the table in my home. ever since my ps3 has not been connecting with the controllers and it shows no picture when i turn it on, and everything is hooked up properly. I just wanted to know is there anyway to fix it without necessarily sending it to anyone(mainly sony)to get this fixed?
    New Friend:
  • 67 Answers
You might have broken a connector, try moving the connected cables from side to side and up and down to see if the problem stops at some position. You can resolder the connectors to the pc board if so
Posted on Nov 30, 2007
The movies want play
  1. Test your Internet Connection
    1. From the PS3 main menu, navigate to Settings.
      • If you're not already at the main menu, hold the PS3 button in the middle of the controller, select Quit, then select Yesto return to the home screen.
    2. Select Network Settings.
    3. Select Internet Connection, and verify it is set to Enabled. If it's Disabled, make sure to select Enable.
    4. Select Internet Connection Test.
      • If you are able to connect to the Internet, check your date and time settings.
      • If you are unable to connect to the Internet, you may be having network connection issues.
  2. Refresh your Netflix Iogin information
    1. Begin from the PS3 Home Screen.
      • If you're not already at the home screen, hold the PS3 button in the middle of the controller, select Quit, then select Yesto return to the home screen.
    2. Navigate to the TV/Video Services section and highlight Netflix.
    3. Press X.
    4. Immediately after pressing X, press and hold both Start and Select and continue to hold them down until a message appears asking Do you want to reset your Netflix settings and re-register?
    5. Select Yes.
    6. Enter your Netflix email address and password.
  3. Reinstall the Netflix application
    1. From the PS3 Home Screen, navigate to the TV/Video Services section and highlight Netflix.
    2. Press the Triangle button on the Playstation controller.
    3. Select Delete.
    4. Select Yes.
    5. Download the Netflix application to your PS3.
    6. From the PS3 home screen, navigate to the TV/Video Services section and select the Netflix icon.
    7. Select Yes on the Are you a member of Netflix? screen.
      • You may be prompted to sign in to your PlayStation Network (PSN) account first.
    8. Enter your Netflix email address and password.
  4. Troubleshoot your Internet Connection
Oct 22, 2013 | Netflix
Why wont my ps3 controller connect to my ps3 console
Most often this is because the controller is already assigned to another system or lacks the charge to send/recieve a signal. The simplest way to solve this is to connect it to your PS3 via the USB charger cable, then try pressing the Home button again. If the problem persists, there is another fix; On the back of the controller next to the screw that holds it together is a very small hole. Try inserting a pin into the hole and hold it there for a few seconds, then try the above method again. This is a hard reset for the controller settings and has solved what few problems I've had with it connecting.
Hope this helps!
Oct 29, 2012 | Sony Playstation 3 (PS3) Console
How to you connect PS3 to to model 37PD5000
Good day!!!
Please try this procedure to connect the PS3 to TV..
The PS3 has a Blu-ray drive that can be used not only for playing games but also for watching high-definition movies. The best way to connect a PS3 to a high-definition viewing device such as a video projector is through the PS3's high-definition multimedia interface (HDMI) output. The HDMI connection can transmit up to 1080p high-definition from the PS3 to the video projector using a single cable. Attaching and setting up the HDMI cable will only take a few minutes and will let you watch high-definition video from the PS3 on the video projector.
  1. Connecting HDMI
    • Attach one end of the HDMI cable to the HDMI output connector of the PS3. Turn the HDMI cable around if it does not slip right into the HDMI output, because the HDMI cable can only fit into an HDMI connector one way.
      Attach the other end of the HDMI cable to the HDMI input connector that is on the video projector. Make sure both sides of the HDMI cable is securely pushed into the connectors of the PS3 and of the video projector. Turn on the video projector. Press the "Menu" button on the video projector's remote. Navigate to the "Sources" setting on the video projector's Menu. Select "HDMI" from the "Sources" setting. Press the "Menu" button on the remote control again to exit the Menu.
    Adjusting the PS3
    • Turn on the PS3. Wait for the "Home" menu to appear on the video projector, although the quality of the video seen from the video projector will be muddied and dark. Navigate from the "Home" menu to the "Systems" icon using the game controller and select the "Display Settings" tab. Choose "Video Output Settings" from the list presented in the screen that appears. Press the right side of the directional pad on the game controller to move to the next screen.
      Choose "HDMI" from the list presented in the screen that appears. Press the right side of the directional pad on the game controller to move to the next screen. Choose "Automatic" from the list presented in the screen that appears. Press the right side of the directional pad on the game controller to move to the "Confirmation" screen. Press the "X" button on the game controller to make the settings active. Return to the PS3's "Home" menu.
    Watching the PS3
    • Insert a Blu-ray disc into the slot at the front of the PS3. Wait as the Blu-ray disc begins to play the video content on the video projector from the PS3 through the HDMI cable.
Please don't forget to rate my answer...I really appreciate any ratings you done..
Thanks for using fixya..
Jul 16, 2011 | Hitachi 37PD5000 Television
My INTEC Turbo Shock 3 Controller is not working i asked my friend i followed to instructions it did not help please help as soon as possible Thanks Peter
I have the same problem. I disconnected the key, plugged the controller with its original cable. Turned the PS3 on, turning controller on, pressing Sync, connecting the key in PS3. At that state, the 4 leds start to flash slower as it detects the key. Problem is I can never connect to console. I mean I press Home and it never connects. Its been working fine before I updated PS3 to 3.5 version.
Dec 27, 2010 | Intec PlayStation 3 Turbo Shock III...
Can't get new controller to connect with ps3
I've had this problem a few times. For me, I resolved it simply by plugging a USB cable into the PS3, and plugging the end of the USB cable into the controller. Hit the Home button and it should connect. However, it tends to lose it's connection when you unplug it so make sure you give it a full charge.
Dec 26, 2010 | Sony Wireless Controller for PS3
Problem with my PS3 Controller
Have you gone onto the PS3 settings menu and used the accsessories option to connect them first?
Jul 28, 2009 | Sony Playstation 3 (PS3) Console
I want to connect my ps3 to the internet. I have a wireless connection on my desktop computer at home. I have a wireless card for my connection. Wireless service is from Alltel. Could you please help me to...
Hi there.. I set up my ps3 wireless connection up just now its quite easy really.. All you do is go to
1. Network Settings
2. Internet Connection Settings
3. Select a setting method
4. Click EASY *note this may take cpl mins*
5. two options are on the table Wired connection or Wireless
7. Click on your internet name that appears if it is the one you have
8. WLAN SECURITY SETTINGS.. I usualy put None HIT X to continue
9. Now you should be all set its going to confirm your internet is set up and running properly
10. Now enjoy your online ps3 gaming!
Best of luck and hope that helped out!
Jan 14, 2009 | Sony Playstation 3 (PS3) Console
We have an Intec G7789 Infinite Play wireless controller and we can't get it to work with our PS3. We have tried everything that the instructions say but it won't connect.
I dun really know how I did it, I had the same problem as u guys. And I try all sorta method.
  1. the last method that I tried was to leave my USB receiver thing in and then restart my ps3. With my controller turned off.
  2. After the PS3 restarts, I turned on my controller.
  3. Then I pressed the home and link button together. And those 4 lights on ur controller will flash really fast.
  4. Then I replugged my USB receiver, and the controller light will flasher a lot slower.
  5. Then just press "home" and the controller should sync with your PS3.
  6. And after that NEVER remove ur USB. LOL. After that, everytime u turn on ur PS3 just press the home button and the controller should sync with ur PS3.
  7. And remember to always to turn on ur PS3 before u turn on your controller.
Well that's my solution, if it doesn't work for u then sorry. Get a refund. I was planning to get a refund but then everything luckily worked out. Good luck and keep trying.
Jan 12, 2009 | Intec PlayStation 3 Infinite Play Wireless...
Problems connecting a ps3 controller
Here's how to connect it tou your ps3. Mine works perfectly guys.
1. Turn your ps3 off without the USB key given with the controller
2. Make sure your controller is off.
3. Turn on the ps3
4. Turn on the controller
5. Press on the sync. button of your controller.
6. Plug the USB key into one of your ps3's port
7. When the light above your controller starting to flash slower, just pess the home button and your controller will be sync.
You can't turn on the ps3 with this controller. So turn it on manually than press the home button of the controller to turn the controller on.
If my post doesn't solve your problem, I really don't know how to solve it. I managed to connect mine so I hope it'll be the same for you!
Sorry for my bad English folks! You know... french people =S
Jan 03, 2009 | Intec PlayStation 3 Turbo Shock III...
Sony Playstation 3 (PS3) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
