My Dell Photo Printer 720 has stopped printed, no response at all to print jobs. I have unplugged the printer, no change. I have rebooted the computer, no change.
You can try these steps:
1.Check if the firewall is blocking any printer services
2.Check what port the printer is using (reenable the bi-directional support) and if it's on online mode
3.Disable all the firewalls
4.Uninstall the printer driver and software
5.Delete any items under the ff keys:
HKLM\System\CurrentControlSet\Control\Print\Environments\Windows NT x86\Drivers\Version-2
HKLM\System\CurrentControlSet\Control\Print\Environments\Windows NT x86\Drivers\Version-3
HKLM\System\CurrentControlSet001\Control\Print\Environments\Windows NT x86\Drivers\Version-2
HKLM\System\CurrentControlSet001\Control\Print\Environments\Windows NT x86\Drivers\Version-3
Optional***
6.Delete any non default items under the ff keys:
Note: ONLY THE NON DEFAULT ITEMS SHOULD BE DELETED
HKLM\System\CurrentControlSet\Control\Print\Monitors
HKLM\System\CurrentControlSet001\Control\Print\Monitors
Default items are as follows:
AppleTalk Printing Devices
BJ Language Monitor
Local Port
PJL Language Monitor
Standard TCP/IP Port
USB Monitor
Windows NT FAx Monitor
7.Delete any items under the ff keys:
HKLM\System\CurrentControlSet\Control\Print\Printers
HKLM\System\CurrentControlSet001\Control\Print\Printers
8.Completely remove drivers by doing the ff: (Option for comm failure because of the upgrade from xp to vista)
Ensure there are no documents in queue.
Disconnect printer’s USB cable.
Click
the Start pearl, then click All programs, Printers, Dell xxx (where
“xxx” is the printer model number) and then Uninstall. Complete the
uninstall utility.
From the start search box type spool and press .
The spool folder located at c:\windows\system32\spool opens.
Rename c:\windows\system32\spool\drivers\w32X86 to c:\windows\system32\spool\drivers\backup.
Rename c:\windows\system32\spool\prtprocs\W32X86 to c:\windows\system32\spool\prtprocs\backup.
9.Restart the computer.
10.Check th services status
Start-Run- Type Services.msc and Click on Open
You will see long list of services
You need to make sure following 4 Services are set to Automatically start
Remote Procedure Call RPC
Remote Procedure Call RPC Locater
LexBce Server
Print Spooler
11.Reinstall the latest printer driver
I have a HP Compaq laptop that I am having trouble getting the Dell inkjet 720 printer to work. I...
(More)
I have a HP Compaq laptop that I am having trouble getting the Dell inkjet 720 printer to work. I have installed the driver and a patch I assume was for Windows Vista 32. I am told that I have to have WinHlp32.exe to be able to read any help files on this matter, which I can not find.
I have this printer hooked up to a Dell Inspiron 1525 laptop via USB cable and it keeps telling me...
(More)
I have this printer hooked up to a Dell Inspiron 1525 laptop via USB cable and it keeps telling me that the printer can't communicate with the computer. I had this printer hooked up to a desk top Dell and had no problems whatsoever. I have downloaded the CD that came with the printer onto the laptop and still nothing. Any suggestions? Thanks
I can't get it to print. I have it hooked up to a Dell Inspiron 1525 laptop and it keeps telling me...
(More)
I can't get it to print. I have it hooked up to a Dell Inspiron 1525 laptop and it keeps telling me that the printer can't communicate with the computer. Any suggestions.
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
