I have not had a record player for 20 years. When I had one and I put the arm on the record and it slid across the record to the middle of the record the problem was it needed a new needle. It is the pointed part which contacts the record.
I found this manual info below hope it will help
Victrola VSC-550BT Operating Manual
https://www.manualslib.com/manual/1341772/Victrola-Vsc-550bt.html#manual
Victrola VSC-550BT Operating Manual: Troubleshooting Guide
https://www.manualslib.com/manual/1341772/Victrola-Vsc-550bt.html?page=15
SOURCE: counterweight on my technics 1200 wont catch
It doesn't screw on, it pushes on....
"With the tonearm locked in place, put the anti‐skate
dial on "0" and push the counterweight onto the rear of
the tonearm. Make sure that the numbers face to the
front of the turntable. Turn the weight until you feel it
"click" into place.
Unlock the tonearm from the rest, and move it
toward the middle, about one inch from the edge of the
platter. Hold the arm off the surface with your right
hand on the finger lift. Begin turning the counterweight
one way or the other, until the arm seems to just
"float".
As seen in the picture, the arm, when properly
floating, will not face up nor down.. it will stay
with the platter. It may take a few tries to get
correct. Lock the tonearm back on it's rest.
Holding the rear, silver, section of the counterweight
with one hand, use your other hand to turn JUST the
number ring. It doesn't matter which direction you turn
it, but you will want "0" to face up when you are done.
Using just one hand, turn the entire counterweight
(the silver part) COUNTERCLOCKWISE until the
recommended tracking force is achieved. New
cartridges will tell what the ideal number is. As a rule of
thumb, however, most "hi‐fi" cartridges track between
1 and 2 grams, while most DJ cartridges track between
3 and 5 grams.
Set the anti‐skate dial to coincide with the tracking
force... in other words, if the tracking force is 2 grams,
set the anti‐skate dial to "2". The exception is for DJ's
who scratch and back‐cue. Your anti‐skate must be left
on "0". "
SOURCE: Turntalble stylus sliding.
The head-shell weight is clearly different and you would need to re-set the arm balance.
this is usually done from the back of the arm where the counter balance sits.
Cartridges have a STATED tracking force usually in grams.
Most arms are roughly calibrated to weight but not always.
http://turntablebasics.com/align.html
See that page for more information
Hope this gives you the information you need
Bob
Moderator
It would be very decent of you to consider the quality of our expert’s answers and judge them accordingly as you pass through FixYa.
Thank you
Testimonial: "very helpful, but upon doing it, the audio quality is appealing and still skips. the stylus has broken and will be returning it thanks alot a++"
SOURCE: Tone arm skipping records.
The anti skate adjustment. And if you scratch @ all....move the weight all the way in and take off the little extra one that screws in on the back. Also a great tracking needle is a M44G.
SOURCE: my arm slides across.dont no
hello george!
first of all remove any needle protectors provided, there is some "weight" on the arm (at the opposite end from the needle). Release the tonearm, you have to turn the weights untill the arm is in balance, then turn 2 and a half so that the needle will go down (2.5 grams), this is the optimum pressure for the needle (pick-up), some people will tell to do more pressure on the pick-up but this will result in higher wear down. On the other hand necessarily this is needed for environments with higher vibrations like discothekes. Be careful not to allow the needle to drop onto the mat or the turntable platter during this adjustment.
The next step is to adjust (if available) the anti-skate adjustment. Set the antiskate adjustment to the same number as the needle pressure setting (i.e. 2.5 grams would be an anti-skate setting of 2.5). If you are back cueing or scratching, then set the anti-skate setting to 0.
regards
Thank you for using FixYa! A four thumbs up rating is appreciated for answering your FREE question!
SOURCE: I have a magnavox micromatic record player that
Is this an old 60's model?
If it is you can find some videos on servicing them on YouTube.
