SOURCE: drive pulley won't come off engine shaft
put the nut back on were it is even with the stud and hit with a hammer while pulling on the pulley
SOURCE: Hello, I have a Craftsman Model 917.377790
Sounds like you lost the drive key out of the crankshaft, it's usually half-moon shaped and keeps the blade hub and the crankshaft turning together, the bolt just holds it all on the end of the crankshaft.
Hope this helps!
SOURCE: PTO clutch stop needs replacing 2130 Cub
take cover off flywheel so you can hold it from turning.or use a air compressor on clutch bolt
SOURCE: clutch adjustment on a John Deere JX 85 push mower
my jx85 when cutting grass with my jx85 the power to the blade dies if i lift it up the power will come back put it back into grass it dies again any ideas please
