Question about Kenmore 62602 Electric Dryer
Kenmore Dryer I have a Kenmore dryer that is about 5 years old. When you push the button to start it you can hear it hum but the drum won't turn. If you let go of the button it stops. If you do this three times in a row it trips and it won't even hum.
  • 213 Answers
Re: Kenmore Dryer
The bearings in the motor are locked up. they are sealed so you have to replace the motor to fix it.
Posted on Nov 26, 2007
0 characters
3 Points
My dryer won't start. When i activate the start switch I hear a hum like the motor is bound up.. I opened the top and the drum is not stuck and the belt seems in good shape. The unit is about 4 years...
check the blower wheel sometimes objects get caught in it not allowing it to spin. If it is clean open the dryer door push and hold the door switch and push start while it is humming rotate the drum. if it starts to spin then you need a new motor it will run you probably 150 - 200 dollars
Jul 14, 2011 | Frigidaire FEQ1442ES Electric Dryer
I've got a 4 yr old Roper electric dryer that won't start up. The belt is fine and the drum spins freely. When you push the button to start it will hum but won't turn the drum. I've got...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
Jul 03, 2011 | Roper RGX4634KQ Gas Dryer
My Frigidaire Affinity electric dryer will not start. Its only just over 2 years old. the timer counts down but the drum will not turn nor is there any heat. I've tried jumping the dryer but it still will...
Listen, when you push the start button to hear a low hum, if you do hear this it maybe that your belt is broken. This is an involved job but can be done if you are handy.
Jan 22, 2011 | Frigidaire AEQ6000ES Electric Dryer
Kenmore dryer model 86950100, when I push the start button it just hums and will not start.First time it did it I waited 1/2 hour then it ran fine for couple days and now it started again, just hums. I...
the humming is coming from the motor,if you can spin the drum by hand and it moves freely you need to replace the motor,if it's hard to move you need to take the dryer apart to see why it's hanging up,the overload resets on the motor that's why after a while you'll hear the hum again,if you hold the button to long you'll pop the overload
Mar 26, 2010 | Kenmore Dryers
Hum but wont start
The slight hum you are hearing is the start windings in the motor. This is a common problem in the kenmore dryers and there is nothing you could have done to keep it from happening. the part number on the motor is 279827 and price from sears is $105.99.
Oct 03, 2009 | Kenmore Dryers
Kenmore electric dryer shuts off after 5 minutes and won't restar
when you try to start it again do you hear a humming comeing from the motor? can you jump start it by turning the drum while holding the start button? If you say yes to these questions you have a bad motor.
Jun 21, 2009 | Dryers
Kenmore dryer not running
Ticking sound is the timer running--so it is not the problem unless a contact has failed or a wire has come loose.  Broken door switch, thermostat failed in open position, or clogged lint filter/exhaust vent/outlet would keep unit from running.  If you can hear the motor running but the drum is not turning then the drum belt is broken.
Jun 04, 2009 | Dryers
Dryer motor
if the motor buzzes when you push start then it is a bad long as the drum turns freely by hand.
Oct 29, 2008 | Whirlpool LER4634J Electric Dryer
Dryer drum will not turn
Try pushing start button while turing drum clock wise and see if drum will start spinning, sounds like bad start winding or relay
Sep 17, 2007 | Estate EED4300SQ Dryer
The Drum on my LG DLE2512W Dryer will not turn
no problem with motor or control board. fault is with the motor capacitor only. this is often attached to the motor or near it. the value of the capacitor will be printed on it (usually about 8uf) and you should be able to source from an electrical spares shop
May 23, 2007 | LG DLE2512W Electric Dryer
Kenmore 62602 Electric Dryer Logo
131 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Richard Roth
Richard Roth
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
