I've had an Acer 6930 laptop for almost a year. I had the two Usb ports go bad on the right side and got a BSOD stop error while burning a Dvd. Sent to Temple repair. They replaced main board and hard drive (unfortunately.) Computer runs now but turns off suddenly for no reason after 2 - 10 minutes. I have tried only on cord or battery (both battery and cord work fine.) Computer will even turn off just running BIOS or in safe mode.
I'm thinking from what I've read on this site possibly three problems: 1. Power button is shuttting down computer. I had to power off the computer a lot by holding down power button. Computer failed to go into sleep mode often. It would turn off the screen - leaving me no other option. 2. When Temple put computer together, some part not hooked up properly 3. Overheating problem - computer always ran hot especially in the lower left corner of the keyboard
this is an overheating problem, computer have a thermal protection sensor that senses extreme temp.
i suggest return to your service provider and have them check again, it could probably cause by, the fan isnt plug or there is a lot ob obstruction to exhaust that tned to build up heat around your pc
Was this helpful?
Yes
No
1 person thought this was helpful
Asker's Testimonial
You were right. The next time I turned on the Acer laptop I noticed the fan was not running at all. Sent to Acer repair work fine now!
" - M Patterson
There is a key to activate bluetooth, but when pressed, a red cross appears on the screen, do I need...
(More)
There is a key to activate bluetooth, but when pressed, a red cross appears on the screen, do I need an add-on ?
how do I turn on bluetooth on my acer aspire 5738z? It has a button on the left top corner but...
(More)
how do I turn on bluetooth on my acer aspire 5738z? It has a button on the left top corner but nothing happens when i press it onther than it comes up with a big red x sign
Acer aspire 5720 no start up.Tried resoldering cmos battery,tried checking for dry joints ,removed...
(More)
Acer aspire 5720 no start up.Tried resoldering cmos battery,tried checking for dry joints ,removed heatsink and CPU replaced with new heatsink compound,tried to reset bios without success with fn + esc.tried using alt + f10 does this work? anyway no success.It actually worked the other day and all that day but next day same story.Help
