SOURCE: Dish Network DVR
You have what is called a diplexer in the back of the the receiver in the front room.It looks like a splitter.If it is put back on in the wrong way you will have a fuzzy screen.look at the diplexer,you will see in/out which would be the input on a regular splitter,then you will have one side that would be one of the 2 outputs that will say SAT,the other side is UHF/VHF.The chances are that when you plugged them back in you had them swapped.Try changing the 2 cables around.If that doesnt work try changing the assigned channel to 68.You can also try doing a auto channel search on the tv in the room without the receiver.this will find the channel that the front room receiver is broadcasting the signal on.Chances are though that your diplexer wires are configured incorrectly.remember,the in/out should plug into the back of the receiver (satellite in)and the UHF/VHF should be going to the other room with the problem and the SAT side of the diplexer should be wired to the satellite dish.GOOD LUCK! rate me with the outcome please.
SOURCE: Unable to Tune TV to Sky + RF output
Hi.
The problem is that the modulator output frequency of your sky box is exactly the same as for example chanel 5 on your terestrial aerial.
You need to change this number to a different one thats clear of local terestrial transmissions
1) Select the Services button on your Sky or Sky+ remote control.
2) Type in 401 [select] on your key pad and you will get to the installer menu. You cant gain access to this via the drop down menu as it is designed for the Sky Engineer to use.
3)
Select Option 4 to configure the RF outlets on your Sky Digibox.
4) The option RF Chanel Number change this number from example 35 to 60 .
You may need to do this using other numbers 26 34 55 etc
Every time you alter the number store it then try & tune TV to sky.
Any other sets in the house connected by RF leads will require retuning for sky.
Save new settings and you should find that your RF outlet to TV works fine.
http://dysonmanuals.llc.nu
Chris.
SOURCE: fuzzy tv screen that says lost signal (no dishnetwork signal)
Here are a few suggestions,
*Check your connections to make sure none are loose.
*Try checking the Dish box to make sure everything that should be turned on is actually on.
*Also make sure channel 3 is the correct channel by contacting your service provider.
I hope theis solution is helpful. Please take a moment to rate this solution.
SOURCE: Should be controllng one box. is controlling 2 boxes
Unfortunately, there is no solution for this issue. The remote control sends out an infrared signal, which can be picked up as far as 40' away from the device. And to make things worse, the signal will reflect off any surface such as glass, mirrors, or even brightly painted walls.
The only way to solve the problem is to block the path of the beam to the other room. This may require closing a door or drawing heavy drapes closed.
SOURCE: have att uverse receiver in bedroom hooked to a
Read in other forums that some lcd tv may interfear with infarated signal....I didn't know this when i had my problem had to put my reciver inside closet away from tv for it to work......
