SOURCE: CALLER ID
Negative, the SX 50 does not support CID. You can upgrade the Mitel or use a CID Multi line interface to a PC. Here is one such model.
http://www.callerid.com/
If you go to the bottom of the page on the right, click on how it works. Hope this hlpes.
SOURCE: Our phone won't allow us to call 866 numbers
It's in a table of allowed numbers. If you're familiar with the system, you ought to be able to find where 800 and 888 are allowed. Just add 877,866 and 855 as entries.
If ARS is implemented, you'll find your entry in the 700 table, maybe :-)
I don't envy you if that is the case.
SOURCE: mitel sx 50.. How to unlock room phone..how to
Attendant
To apply Do Not Disturb on an extension:
• Press the DO NOT DISTURB function key or dial *85. The LCD shows EXT-NUMBER ?.
• Dial the desired extension number.
• Press the DND ON softkey.
• If desired, press the NEW EXT softkey to apply or remove Do Not Disturb on another extension.
• Press the EXIT softkey.
To remove Do Not Disturb on an extension:
• Press the DO NOT DISTURB function key. The LCD shows EXT-NUMBER ?.
• Dial the desired extension number. The LCD shows the extension number and DO NOT DISTURB.
• Press the DND OFF softkey.
SOURCE: SX-50 Mitel wake up calls won't go through to
Your Wake up device is in DND.... it either didn't hang up or it didn't answer. You should contact your vendor to have them check the RAD (Recorded Announcement Device).
Unless you know the extension number associated with it (the installers use different numbering from site to site and I couldn't even guess for you), you won't be able to clear the DND. If you do know the ext number... follow these instructions from the attendant console.
