Yes
SOURCE: durabrand tv model#BH2004D need code for GE universal remote
For the GE Universal Remote (RC24991-b), 0157 works (for me) with this Durabrand model
SOURCE: NEED CODE FOR SETTING GE UNIVERSAL REMOTE FOR SONY TV
I HAVE A GE UNIVERSAL REMOTE AND I NEED THE CODE TO PROGRAM A SONY TV
SOURCE: universal ge 24911 remote?
http://www.jascoproducts.com/support/download-files/RemoteCode-4-digit.pdf
SOURCE: i have lost the ge universal remote guide for the
These are the steps on how to program your GE Universal Remote Control without the list of codes.
1. Manually turn on the device to be
controlled.
2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
3. Press and quickly release the desired device button. The red indicator blinks off once.
4. Press the ON•OFF button repeatedly (up to 300 times) until the device to be controlled turns off. The red indicator blinks off with each button press.
Note: Code Search starts from the currently stored four digit number under that mode. Sometimes the
first code that “works” with your device may only
allow limited functionality (e.g. the MENU button
might not work). There may be a code that performs
more functions. Continue the code search process
until the best code is found.
5. Press and release ENTER to install the code.
SOURCE: need code for samsung tv on a GE universal remote
Most GE remotes use the same codes for particular brands of television. These are the standard codes for Samsung TVs:
0105, 0077, 0076, 0109, 0007, 0009, 0004, 0005, 0085, 0172, 0942, 0358, 0012, 0015, 0080, 0104, 0106
Try each one with the power, volume and channel buttons. If one doesn't work, or only partially works, try the next in the list.
If none of these work, please post back and I will try to find a specific code for you.
Please rate this solution if you find it helpful. Thanks.
