Tax number for revonia rekgala mashabelo
SOURCE: CHANGE TAX %+ & TAX- ON MY CASIO JF-100TE CALCULATOR
1. Press [AC]
2. Hold [SET/%] key for about 2 seconds
3. Press [TAX+]
4. Input the tax rate
5. Press [SET/%]
SOURCE: tax rate
press button CA then TAX+ and enter tax rate figure, then press TAX+ again to store.
SOURCE: Tax function settings
Press C/AC. Press and hold down SET/% until "SET" appears in the display. Press TAX+/TAX RATE. Enter your new tax rate. Press SET/%. Done!!
SOURCE: Setting tax rate on ibico 212x
Press AC then Tax+, enter your % tax rate. i.e. 15.
Finally set the tax rate by pressing the Tax+ button again.
SOURCE: Trying to change the tax buttons on my CASIO HR-150TER
I solved this problem..
1. press and hold your % Key the zero on your display will disappear While the % is pressed, press and hold your CA key. After a short delay the calculator will print a line #--------------- when this happens release the keys.
2. Enter your tax rate for me this was 7.75 then press your Tax+ key.
now your rate is set.
You can then use this key as normal. :)
Hope this helps.
