SOURCE: F2 code and consistent beeping with my Maytag Electric Wall Oven model CWE5800 or CWE4800
The F2 code indicates a stuck relay. You will have to replace the relay board. It may be a stand alone board or it may be part of the ERC Electronic Range Control. If you know how to check you won't have to call a tech.
SOURCE: oven
I used the self cleaning mode for 2 hours and the error f2 keeps flashing and beeping, I did try to power off with the breaker and left it off for about a half hour and it still continues to beep and flash f2, what should I do?
SOURCE: Kenmore Oven going crazy
The bang may have been an element arcing over. Turn off the power and remove the element. If it shows any form of damage, replace it. If you're not sure, use a continuity checker to check it. If you have two elements...do this for both. You will likely find the problem.
SOURCE: my kenmore oven is beeping
Please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacment of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
KENMORE Range/Stove/Oven Fault Codes – 362 Series (General Electric)
F1 = Stuck Touch Pad Key - Replace Electronic Range Control (ERC).
KENMORE - 911 Series (General Electric/Roper)
F0-F1-FF = Failed transistor in Electronic Range Control (ERC).
KENMORE Range/Stove/Oven Fault Codes- 665 Series (Whirlpool)
F1-E0 EPROM Error - Electronic Range Control (ERC).
F1-E1 EPROM Error - Electronic Range Control (ERC).
F1-E2 U/L ERC Errors - Electronic Range Control (ERC).
F1-E3 Fuel Type Fail
Kill power 30 seconds-Cancel-Start/Enter-5 seconds-Should see “E” for electric-
“9” for gas-If code changes again-replace Electronic Range Control (ERC).
KENMORE - 790 Series Electronic Oven Control (Frigidaire)
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal checksum error.
Runaway Temp = Replace Electronic Oven Control (EOC).
Kill power 30 seconds - if error returns - replace Electronic Oven Control (EOC).
SOURCE: "F1" DISPLAYED AND BEEPING
F1-->Failed Thermistor Control Replace ERC
you will have to replace the ERC or Electronic Range Control or the touch pad.
