Question about Canon PowerShot A70 Digital Camera
SD card formatting
I inserted sd card and started format process, but screen is black and seems frozen.
Get a black or streaky display when trying to take a picture, when taken in that mode through the viewfinder, the picture looks either black or streaky as well. Changed card, that's not the issue, sometimes goes away and works normally, any idea what's wrong?
  • Canon Master
  • 4,738 Answers
Re: SD card formatting
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
Posted on Dec 08, 2007
0 characters
3 Points
Insert sd card again
At this time we recommend you use a different SD card and format it. SD cards can become corrupted and the camera may not recognize your card any longer.
Apr 13, 2014 | Panasonic Sale Lumix Dmc-ts20 Waterproof...
C190 does not read the sd card even when sd card format is ok . it is giving a message 'memory card requires formatting' 'please format memory card or insert another card' however inserting a new...
Hi sir
  • Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from or
  • 2 Open up 'My Computer'. You should see it under the list of available drives.
  • 3 Check its contents first to make sure that you have the right drive.
  • 4 In 'My Computer', right-click on the drive and choose 'Format'.
  • 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  • 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
  • May 20, 2010 | Kodak Easyshare C190 12MP Digital Camera...
    How do i format my sandisk in my panasonic lumix FX40
    Hello :
    1: Insert the SD card into the multi-card reader on your computer. Most newer personal computers and laptops come with a multi-card reader. If you don't have one , then you should get one ! Just make certain that you insert the SD card into the appropriate slot. A multi-card reader picture is shown : There another types of multi-card reader , so you can choose the best one for you .b74156b.jpg
    2: Right click once on the Windows "Start" button.
    3: Click once on the "Explore" option.
    4: Find the SD card in the "Folders" section of the window.
    5: Right-click once on the SD card icon.
    6: Click once on the "Format" option.
    7: Make any desired changes using the options on the "Format" window. Default options are recommended, but it is possible to change the file system and allocation unit size. If you change any of these settings and want to change back, click once on "restore device defaults." To perform a quick format, click once in the "Quick Format" box. A quick format means only that all files will be removed from the SD card, but it will not be checked for bad sectors. A quick format is considerably faster than a full format, but neither takes too long.
    Click once on the "Start" button on the "Format" window to begin the formatting process. A warning window will pop up to make certain you want to proceed with the formatting of the SD card. Click one on the "Yes" button to move on.
    Click once on the "OK" button on the "Formatting" window that pops up when the formatting is complete.
    Click once on the "Close" button on the "Format" window to exit the formatting process.
    good luck .
    please don't forget to rate !
    Apr 04, 2010 | Panasonic Lumix DMC-FX12 Digital Camera
    When i take pictures rapidly the screen says ''processing'' , often for up to10 seconds or more. this happens with a 2 gig non hi def card and 8 gigHD card. regardless of pixel setting.this has just...
    It could be caused by your SD card needing to be formatted.
    Format your SD card. NOTE this will delete all existing data on your SD card.
    Do the following:
    1. Insert the memory card into the camera. Make sure the card is firmly seated (push in the card until it clicks into place).
    2. Turn on the camera.
    3. Press the Menu button, then go to the Setup Menu.
    Scroll up or down to the Format option, then press the OK button
    Jan 25, 2010 | Kodak EASYSHARE Z1285 Digital Camera
    It is not formatting the memory card? says conitue and then back to it after trying to format, no other message.
    Here are some possible solutions to your error mgs.
    The lever on your SD card might be turned the wrong way so the SD card is reading protective.
    Please turn the lever and try again.
    The SD card might not be supported by the model: Your camera Memory card support is SD/MMC up to 2 Gigabyte and SDHC up to 8 Gigabyte
    The SD card might not be faulty, try another card, since the camera could give you a message like the one you're experiencing.
    Try with a different SD card that is supported by the camera.
    Jan 15, 2010 | Kodak EasyShare M320 Digital Camera
    Kodak EasyShare DX4530 Digital Camera Digital Camera Cannot format memory card After I inserted new card, it says that memory card required formatting....I hit warn me that formatting will...
    If your using more than 2GB of SD card or if yous using the SDHC card it will not format the Memory card.
    Try to used the recommended Memory card 2GB or 1GB SD card It will reformat your card. Too Much or too High SD card is not compatible on DX camera series
    Nov 08, 2009 | Kodak EasyShare DX4530 Digital Camera
    SD card formatting
    I have to take the batteries out everytime i want it to unfreeze.
    Nov 20, 2007 | Digital Cameras
    Sd card formatting
    Does SD card work in PC? HP R707 will not work with SD card larger than 2GB.
    Oct 22, 2007 | HP Photosmart R707 Digital Camera
    Card Error
    If you should see the warning message "CARD ERROR" in the LCD Display, please check the following: Always choose reliable quality SD Cards. Toshiba Digital Cameras are tested for maximum performance with Toshiba SD Cards, Delkin SD Cards and Panasonic SD Cards. These are leading brands in the development of standard SD technology. Performance by other brands of SD cards may vary. Check the LOCK switch on the SD Card. The camera can not save images to an SD Card when it is in the lock protected position. If the SD Card is NEW, it may be necessary to FORMAT the card. This only applies to NEW SD Cards. If you format a card with images, all images will be erased. You can FORMAT your card periodically to maximize capacity and erase 'unseen' files, please be sure to download all images before choosing FORMAT as all images will be erased. Your Toshiba Digital Camera is designed for use with SD Cards. MultiMedia Cards are similar in size and shape to SD Cards, although with close inspection you will find that SD Cards have a different 'PIN" connection configuration, are slightly thicker in size, and have a manual slide LOCK switch on the side. Toshiba Digital Cameras are not designed or guaranteed to accept MultiMedia Cards. Please be sure to look for SD Cards from Toshiba, Panasonic and Delkin, the leaders in SD Card Technology.
    Sep 11, 2005 | Toshiba PDR-3310 Digital Camera
    Canon PowerShot A70 Digital Camera Logo
    57 people viewed this question
    Top Canon Digital Cameras Experts
    Are you a Canon Digital Camera Expert? Answer questions, earn points and help others
