VCR shuts off after tape is inserted. I tried a head cleaner. Did not help. What more can I try?
    Sergeant:
  • 159 Answers
find the motor and belt that controls the loading of the tape.
put the vcr on its side and put the tape in watch closely on the pulley mechanism. try and give that pulley wheel a few more turns in the same direction the motors trying to turn it after it stops. sounds like the tapes not sitting all the way down. if you can get it to play then you need a belt there if not continue to watch all the operations hopefully eventually you will see why it wont go.
Posted on Sep 19, 2018
  • 883 Answers
SOURCE: Tape ejects just after insertion
the end-of-tape optical sensor is at fault. either it is very dirty, has failed or something else is detecting end of tape. many VCR's now will auto-eject the tape upon end of tape detect
Posted on May 20, 2007
premtech
  • 934 Answers
SOURCE: Magnavox combo vcr dvd
What you're describing is common when the center LED has failed / gone out. If you're really good at taking a unit like this apart and putting it back together - and not too bad with a solder stick you could attempt this one yourself... It is a pretty intensive repair but not difficult for a good shop just time consuming. The part isn't too expensive either, just an infared LED... In fact, we've run a bit short on stock once in awhile and bought one of the off the shelf versions from Radio Shack which worked just fine. Good Luck Bill
Posted on Jun 12, 2007
SOURCE: Try to playback the tape and the screen is all blue
your heads motor ( drum ) cable may have have come loose or is dirty - since the cleaning tape made some difference the heads were dirty or almost worn out ( cleaner tape is abrasive ) so now there isn ' t enough signal ; if your date and time display worked only in play ? ( still works for camera record video ) your guides were out of alignment - and the cleaning tape took your guides even further out of alignment ( alignment here starts at $ 50 + shipping )
Posted on Sep 05, 2007
QTipsX800Pro
  • 48 Answers
SOURCE: My Camcoder says eject the cassette
Use a Sony head cleaning tape they work perfectly and you let them run there 10 second corse. Then your sharp will run perfectly...
Posted on Feb 19, 2008
SOURCE: VCR continually tries to eject the tape after it is inserted
If you have cleaned the head with a good head cleaner and you are still having a problem...the belt is probably worn. A good head clean should fix the problem.
Posted on Mar 19, 2009
VCR tape loads and put tape around drum but then kicks tape out without returning the tape to the cartridge or playing. tape is then hung up inside the mechanism.
Dirty heads or rollers usually cause that or the tracking path has worn and the rollers are out of alignment. I would try a tape head cleaner first. Video / music stores or electronic stores usually sell them. You get a special tape to insert and cleaning solution.
Dec 13, 2015 | Televison & Video
I have a go video dvd/vcr combo. The vcr makes a hissing noise when played. Also shows poor tracking. Is it worth fixing?
Start off with using a vcr tape cleaner make sure you read instructions some are just a brush while some others cleaners have a small liquid cleaner to add to it after using cleaner do not worry about rewinding it until another day you may need it.you can also try switching the progressive scan off if being used.If its eating tapes the tensioner could be loose or wore out or the locking mechanism is not working properly when tape is inserted.If you are not experienced in this field I recommend letting a shop look at it if so cleaning it is about the only thing you do also try opening the vcr tape bay door taking a deep breath and blow inside it without a tape in it do this several times it may just be dust and you can try unplugging it for 10 minutes to reset the device to see if its a stuck communication glitch in the board for the head motors.I hope one of these three basic tricks helps you.
Mar 02, 2015 | GoVideo Go Video DVD/VCR Combo
I recently brought out my vcr and am trying to clean it with Maxell VP-201 VCR pro head cleaner... but it doesn't say how to use it. Do you know where to apply the cleaner on the tape before I put it...
You can usually apply a couple of drops on the tape itself as it will not harm. The tape itself might have a hole located on the cassette itself close to the see through cover. We normal tell people to drop a couple of drops into the tape area
Jul 15, 2011 | Maxell VHS VCR Head Cleaner Wet Type 1...
I recently purchased this from a pawn shop. I tried playing back a few of my old tapes and the video and audio is choppy. Is it the camcorder, settings or tapes?
It is possible that the camcorder was off use and resulted in drop of values in the servo sections. First of all open the tape door section and do a good cleaning of the audio/control head . See if any dirt had accumulatted onthe heads, be verry careful to clean or use a good quality cleaning tape. Check and see if your old tapes are tight , rewind and forward before playing stored tapes. If this wont solve the choppy playing, thenit is possible that the servo section of the camcorder needs attention. Get help if not familiar as it needs experience to open and probe, but this can also be very expensive. Hope you try the cleaning first. Good day
Aug 06, 2010 | Sony Handycam DCR-TRV103 Digital Camcorder
Keeps going to "err" and shuts down when I insert tape
Hi. your VCR is experiencing a major mechanism fault within the head assembly. the head is unable to read the tape. in this case, you will need to replace the main head assembly in this unit.
May 18, 2009 | Emerson Televison & Video
Mar 18, 2009 | Zenith VR4127 VCR
No video output when played on vhs
try cleaning the cylender head of your vcr you can do that by opening the unit or buying vhs vcr casset cleaner....
ps : check if you have to switch between tv and vcr via remote , and when you insert the vhs tape you are able to rew and frw and press play normally...if these are ok usually its a little dirt onthe cylender head....hope this helps...
Jan 01, 2009 | Panasonic DMR-E75V DVD Player/VCR
VCR functions do not work (play, record, ...)
Sounds like the idler assembly isnt working. Without this assembly, the system cannot get the tape to actually move, and most systems will shut down if the tape isnt moving to prevent damage to the tape. In truth, this can be a complicatred repair, requiring the machine to be taken apart quite a bit. I would suggest taking this kind of a problem to a repair shop, but with the cost of simple VCR's coming down constantly, and the upcoming switch to DTV making the machines tuner obsolete, it would probably be more economical to just replace the machine.
Feb 15, 2007 | Mitsubishi HS-U110 VHS VCR
Televison & Video Logo
142 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
