Spa get to hot and trips the breaker and burns out heater
SOURCE: gfci breaker for spa
gfci's are designed to trip if they receive voltage on there ground/neutral side, therefore my vote is for Smithbrother I would say there is probably a partial short somewhere in you system.
SOURCE: 50 amp GFCI breaker trips after spa runs for 45
More than likely, it's the element. They begin to 'leak' small current as they get old and this will trip the GFCI
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
SOURCE: SPA Filter on while Spa is Heating
you have one jandy valve ( the suction valve in front of the pump) that is not working right when you press spa mode. have someone watch the valves to see if they move when you press spa mode and heat inside the house. if the one in front of the pump does not move and the switch is in operating mode then that valve is bad and will have to be replaced.
SOURCE: I have a spa pac 1100 kw heater it trips the
jkuigjiu9u9uirj9u9jrri89jij9f ijoijog j9j9r hi8h9jrij9jfij9j9dij9jasifj9jifj8ef i8hfh9ufihihfhihd73uurwejhydjjhuynjujjuyvnnydhnhrhhydfhyfhhyrhyyjhhfuhuughurtuguhuerghuhrrguhurhgurgbrguhrrguhrhguherghuhghughfjvnuhuf udfu h8h uhufhuwenuh uh hh unu huwenfui h8ef hwuehfu bufg ubdfuh unuwebf jwbfubu weyfgu huyff uhehfuywehfuyweghufhweufhuwefhuefuefuwefguwefgudfbdbvusfgfudgfugfugsdfsdgfusdusdfusdfsudfg7egrwegfwgefyugydgybefygeyfgywfgygdycgybefygybsyfvwyfbgydvfytyfgefywefy y ge7yfg gyeyf wy yegjhbuvhuvye7fg7egf7g7dg77gd76gwte6t6qge6qt6q6e
SOURCE: my older f series hot springs spa trips the heater
I would check to make sure thats what this calls for could be weak breaker
