Question about GE 24 in. PDW9880LSS Stainless Steel Built-in Dishwasher
Control Module? I have a GE Profile that seems to have a control module issue. I've changed the module and it continues to do the same thing...won't drain at end of cycle and begins washing right away after selecting new cycle. Washes for only about 5 minutes total and then just heats the water...soap dispenser doesn't get rinsed clean either. Any ideas?
    Sergeant:
  • 183 Answers
Sounds like a dishwasher.. You didn't say or give a model number. Dishwasher that do not drain are usually caused by clogged up drain hoses, often right where it connects to the drain or disposer under the sink. In some cases, there's a separate drain pump that is defective, in other cases, there's a drain solenoid, and in others a drain impeller that's broken or clogged. All depends on the model.
Posted on Oct 24, 2017
  • 54 Answers
SOURCE: DIshwasher Cycle TIme INcreases by 20 minutes over two years
Try cutting the breaker off for 5 min, This will reset the control. The issue is in order for a dishwasher to clean the dishes properly the water in the dishwasher needs to be at least 120 deg f. If its not the dishwasher keeps adding more time with the heater on to try to achieve this temp. The dishwasher only uses about 1 gallon of water per fill so if the water heater is a ways away or the temp is not hot enough, the water temp in the dishwasher will not reach 120.
Posted on Jul 04, 2008
jbjaxiis
  • 95 Answers
SOURCE: Water won't drain, Soap Door open with soap still there and stops running at Plate Warmer cycle
Reset the washer manually. Close the machine, and slowly advance the timer till you here the fill valve start. Then let it do it's thing
Posted on Jul 21, 2008
ngfam1
  • 639 Answers
SOURCE: GE profile PDW7880J Soap left on dishes and soap left in dispenser
Dear friend,
ngfam at you service! happy to assist!
Sprayers or sprayer clogged and or pump weak!
Better call service
We sell appliances for 65 years and I recommend this nation wide Factory repair service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Posted on Aug 29, 2008
SOURCE: Dry Dishwasher Soap Still in dispenser after wash.
so here it is...
get a screw driver (you may need a "star" head driver as well), get in there and take out all that you can and clean it (it all comes out pretty easily)...you will find a lot of undisolved soap and hard water build up...rinse it, scrape it, vacuum it...just get out as much as you can...keep note of how you took it apart so you can put it back together...then put 1/2 to a whole gallon of vinegar in and run a cycle (hi-temp if you have that option)...if it was like mine most of your sprayers were gummed up and the water just wasn't moving through the machine...
to avoid this problem...use half of what you have been using of your detergent...and only fill the "pre rinse" section if you are doing pots and pans....and then only fill that half way as well.
after that run a few cups of vinegar through on an empty cycle once a month...
whole job (not including the wash cycle) 1.5 hours...
Posted on Aug 31, 2008
SOURCE: GE Nautilus won't drain after Rinse Cycle
Check disposer plug. If a garbage disposer has been recently installed, it is possible the disposer drain plug was not removed. The drain plug is a plastic piece in the disposer that blocks the hole where the dishwasher hose connects. Also check the hose connected to the disposal. Mine apparently had a kink in it. When I straightened the hose the dishwasher drained at full speed (I recently had a plumber re-route a hot waterline. He must has bent the hose). Hope this helps. If not go to the GE website. That's where I found my answer.
Posted on Sep 29, 2008
How do I remove the cooktop from a GE Profile Dual Fuel J2S968SHSS? I need to replace the Spark Module. Where is that located? I already replaced the wiring harness but cannot get the cooktop to re
Check in the control panel. GE sometimes puts the spark module up in the control panel. I would look there first. Sometimes they put it in the side panel.
Nov 20, 2014 | GE Kitchen Ranges
Electronic control module
Has anybody checked to see if there was any (green in color) corrosion on the connector(s). i.e. ECU or TCM (if automatic).
Feb 17, 2014 | Volkswagen Eos Cars & Trucks
Won't fill, spin, rinse, drain
130. (10000010) Single Rotor Position Sensor Error
The Motor Control Module has found an error in the pattern received from the Rotor
Position Sensor. Likely causes of this fault are a bad connection on the harness between
the Rotor Position Sensor and the Motor Control Module, or a faulty Rotor Position Sensor.
Primary Source: Wiring.
Action: Check for corrosion on the RAST connector of the Rotor Position
Sensor and the Motor Control Module connector.
Secondary Source: Rotor Position Sensor.
Action: Check the Rotor Position Sensor with an R.P.S. tester. Replace if
faulty.
Tertiary Source: Motor Control Module.
Action: Replace Motor Control Module.
Quaternary Source: Rotor
Action: Ensure the correct rotor for this phase of machine has been fitted
May 24, 2013 | Fisher and Paykel GWL11 Top Load Washer
GWL15 fisher and paykel stops mid spin
If the only light on was the spin when it was beeping,
That is fault code 1
1. (00000001) Motor Control Module Fault
The Motor Control Module has encountered an error when writing to an EEPROM address.
Primary Source: Motor Control Module.
Mar 18, 2013 | Fisher Paykel EcoSmart GWL15
Ge profile dishwasher runs for hours
HI, this will occur if there is a major control fault in the timer module or, main control board. Depending on you model, you will need to replace the timer or, control board in this case. this will fix this issue
Jul 15, 2009 | GE 24 in. Profile PDW9280JSS Built-in...
GE Monogram
The control module is damaged and, you will need to replace this device asap. the pump will burn out soon if the control module isn't replaced.
The control module will run you about $109.00
Jun 03, 2009 | GE 24 in. Profile PDW9880JSS Built-in...
Continuous beep after power went off and on
I'm the one who posted on May 23. I tried turning off the breakers and it was still beeped when powered back on. I ordered a new touchpad and control module. When I replaced the touchpad, the beeping was gone, but not all the buttons worked, so I changed out the control module, too, and it works:) I'm going to put clear caulk along the top to prevent spills from leaking through the front panel.
May 15, 2008 | GE 24 in. Profile PDW9880JSS Built-in...
High pitched whine
I have the same problem. Replaced the module and still a continous beep....
Dec 28, 2007 | GE 24 in. Profile PDW9880JSS Built-in...
GE 24 in. PDW9880LSS Stainless Steel Built-in Dishwasher Logo
42 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
