Question about Toshiba 32HL95 32 in. LCD TV/HD Combo
Eject button does not work.
I played a DVD and when I tried to eject it, it did not work.  What do I do now? How can I eject the disc?
  • overloaded Dec 22, 2007
    I accidentally loaded TWO dvds into the single player, neither will load or eject. How do I get them out?!
  • 1,153 Answers
Let stay unplugged for atleast 5min. Then try again
Posted on Nov 25, 2007
I can't get my DVD disc to eject. It will play but won't eject? Any suggestions
You should try unplugging the DVD player from its power source then plugging it back in. Now try to open it and if that doesn't work than you'll probraly have to take it apart to get the disk out but sometimes the DVD players can get worn out or if you have a cheaper DVD player it might just be freezing up on you. I have had these problems before. I just took the DVD player apart to get my disk and then trashed it.
Jan 23, 2012 | GoVideo DV2150 DVD Player/VCR
Dvd player will not eject or play dvd. It just keeps spinning and says "reading." I've tried unplugging for 2 minutes, pushing close/open and stop at the same time(hold for at least 3 seconds)....
Plug the power cord back into the electrical outlet and turn the player ON. Attempt to open the disc tray. Depending on the model number of your DVD player, simultaneously press the POWER + STOP + EJECT buttons. If the disc tray still does not open, simultaneously press the DISC1 + STOP + EJECT buttons.6 Jan 2013
Solved: DVD is LOCKED will not eject. please help. Manual ... - the ...
or try this link. Dvd player will not eject or play dvd Google Search
Oct 18, 2017 | RCA DRC8295 DVD Recorder/VCR Combo
2006 Toyota Sienna with an ADVENT DVD
Well, if its crammed in there from kids shoving stuff in there as kids will tend to do sometimes, then i am sorry to say, you most likely will need to get a new player. Cause general when something is jammed into disc slot, other components that are vital to operation have been compromised. But on the other hand. If it was working and operating fine one minute, and the next it simply just wouldn't eject. Your problem is one of the 2. Is the player making any noise as if it is trying to eject the disc but will not, and can you still at least play the disc and watch it since its already in there? If so. It sounds like you have a bad gear or a little spring that has popped that engages the gear to make the mechanism for disc ejection impossible. Or the main drive belt has dried and broke. Take it to a local tech. 2nd. If its not making any noise when eject button is pressed. The button itself might be bad. Try the remote controls eject button. If it has one, that might eject the disc. Hope this helps. And in tghe future, no paper clip tricks okay. Only damage can occure with that method. good luck,
Apr 26, 2010 | Televison & Video
Will not read disc or eject disc
There's a few things you can try. Turn off unit, unplug from AC for 5 minutes or so, plug back in, turn unit on, hit eject/open.
OR..same as above, but hold the eject/open button, then turn unit on.
Sometimes a combination of these odd procedures actually work. Sometimes holding the stop button, and hitting eject/open works too. Hope this is helpful.
Apr 23, 2010 | Sharp AQUOS Blu-ray Disc Player
Dvd player will not open disc, display lock
Sound like it either has one or two problems, the door is stuck and or the door eject motor has failed. Look in the front to the player for a small paperclip like hole, and use a paper clip to manual eject the and engage the loading mechanism usually located under the door for most cases. Check you manuals troubleshooting section for manually ejecting a CD..
Please leave comment.
Oct 12, 2009 | JVC XV-N312S DVD Player
Upside down dvd inserted
FYI - This might damage the unit, but if you really need to get that DVD out then you can try this at your own risk!
Try unpluging the unit, then plug it back in and press the power button and a split second later press the eject button. This all needs to be done quickly otherwise the unit will try to load the disc.
You can try letting the unit load the DVD. When the unit says "Please eject disc. Playback feature may not be avalible on this disc," press the eject button.
Apr 01, 2008 | Emerson EWR20V4 DVD Recorder/VCR
DVD Stuck in Player
While the above problem is not in the manual, I would try pushing and holding down the Open/Close buttton for an extended period to see if the unit will 'unlock' itself.
Mar 16, 2008 | Sanyo DWM-390 DVD Player
Disc Tray Will Not Eject
Just next to the eject button on the actual recorder there should be a tiny pinhole.  If you use a small paperclip and insert it, then push, you should be able to manually eject the DVD.  Hope this helps!
Oct 16, 2007 | GoVideo Go Video DVD/VCR Combo
Dvd recorder doesn't eject disc
Yes, I'm having the exact same problem -- I can't eject the dvd that's in the player right now either manually or remotely. It plays fine.
Sep 23, 2007 | Televison & Video
Disc Eject won't work after improperly inserting disc and since removing it.
I have an DZ-MV780 with the same problem. I found that the cover plate around the flash hot shoe only has a single screw. If you remove it and pull up the cover you gain access to the gear and lock mechanism. Hit eject and if necessary press on the white gears you see in front of the zoom switch. It should then cause the door mechanism to unlock and open.
Aug 24, 2006 | Hitachi DZ-MV580A DVD Camcorder
Toshiba 32HL95 32 in. LCD TV/HD Combo Logo
135 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
