I have two GE coin-operated washers in a three-family apartment building I own. Both started failing with the same problem in the same week. The clothes come out soaking wet. I popped off the front panel and can see that during the spin cycle, the motor, belt and basket are turning, just slowly. Do I have a bad motor?
IT COULD BE A MOTOR OR JUST A WORN BELT , IF THE BELT IS'NT ABEL TO KEEP THE RIGHT AMOUND OF PRESSURE ON IT THEN IT'LL SLIP BUT IF THE BELT LOOKS TO BE IN GOOD SHAPE THEN YED IT COULD BE THE MOTOR NOT ABEL TO SPIN AT THE RIGHT RPM
Are there any new washing machines made that still have direct drive. That means that the agitator...
(More)
Are there any new washing machines made that still have direct drive. That means that the agitator has two pieces and is not just one part. I told my repair man that my dad had been in the appliance sales and repair for over 50 years before he passed away and he said that normally he doesn't tell people about the new washers as they would be too depressed to learn that they are all garbage. I forgot to ask if him if anyone still makes them with direct drive.
Aquarius wf541. Am trying to unscrew and remove pump filter at front to clean and check for...
(More)
Aquarius wf541. Am trying to unscrew and remove pump filter at front to clean and check for blockages as leaking water all over the floor.. Kick plate removed ok. turned filter anti clockwise as oer instructions but it will not remove. any ideas? have tried pulling with pliers but dont want to use too much force incase plastic breaks
Hi. I've just moved in to rented accommodation. There is no manual for the Neff washer/dryer and I...
(More)
Hi. I've just moved in to rented accommodation. There is no manual for the Neff washer/dryer and I can't figure out how to get it working! Please could you advise?
just bought zanussi zwf682 washer and the manual is in spanish, i would like to download it in...
(More)
just bought zanussi zwf682 washer and the manual is in spanish, i would like to download it in english.
