Question about Gateway 7330GZ Notebook
Gateway 7330GZ laptop. Good battery, good Ac Cable will not turn on?
Charging light wa on then wentout when chargeed. But it will not go withAC or Batt
  • Anonymous Feb 05, 2009
    Mine has become loose at laptop connection and does the same thing. Probably loose or bad connection inside your laptop. Battery is fine and AC adapter and cord are fine. Check the center pin on the connection on the back of your laptop.
  • 51 Answers
The system board on the laptop needs replacement.
Hope this helps :)
Posted on Nov 26, 2007
Power adapter is good, but Gatway MX6025 will not power on. It does power on briefly with battery installed. I've tested the ac adapter with a multimeter and it appears to be good. Green light on,...
Try to check with another adapter if possible.
The connector of the laptop might be damaged. so the battery is not charging and also not staring laptop on AC power. Check the ac connector of laptop.
Jun 08, 2011 | Gateway MX6025 Notebook
I have an nv5468u with Part Number LXWDG02030. My laptop wont charge the battery, I can still turn it on using the ac adapter but it wont charge the battery, the battery light indicator just alternates...
Hi there. Your problem seems to be the battery. Usually when the battery is at the end of its life the indicator stays at 0%. If you are still unsure you can go to download.com and get free battery testing software. Good luck...
Mar 30, 2011 | Gateway NV5468u Notebook
Laptop just shuts down.
If the System is hot when it shuts down, it overheated. if its not to hot, then the AC Adapter or Battery Failed.
Apr 13, 2010 | Gateway 7330GZ (890552601318) PC Notebook
Gateway 7330gz will only run few seconds then turn off
Remove the battery and run off of the A/C power adapter without the battery installed.
If it works, the battery is just discharged too much. After Windows settles, insert the battery and let it charge.
Sep 09, 2009 | Gateway 7330GZ Notebook
Gateway 7330gz Laptop Won't Charge
Could be your connection inside the laptop itself.
They tend to go easily in gateways.
The wear and tear from plugging it in and out.
Cost approximately $70.00 - $100.00 to repair.
Can usually get the best price at a small computer repair store
Jan 12, 2009 | Gateway 7330GZ Notebook
7330GZ won't turn on
I had the same thing happen to my computer 7330 gz and all the trouble was caused by a faulty ac adaptor. Battery wasn't holding a charge either because it's 3 years old and worthless. I got a replacement adapter at best buy for 100 buck and it's universal. Fixed it up just fine and now I'm sharing my solution with you!
Nov 19, 2008 | Gateway 7330GZ Notebook
MY GATEWAY LAPTOP SCREEN WENT BLACK AFTER 20 MIN OR MORE
Look for cracks in the hinges. It is a big problem with the Gateway 7330GZ.
Sep 30, 2008 | Gateway 7330GZ Notebook
7330GZ Gateway laptop keyboard doesn't work
There is one thing you can try. Uninstall the drivers for the keyboard from the device manager, then reboot. The machine will find the keyboard and reinstall the drivers automatically. If this doesn't work, then I'm afraid the Shift key function has failed and the keyboard will need replaced in order to fix it.
Aug 25, 2008 | Gateway 7330GZ Notebook
Gateway Notebook PC 7330 GZ Power Problem
The most common problem is the plastic that covers the switch breaks. It's a poor design. Take out two screws along the top edge from the bottom near the middle and pry off the keyboard access cover. Then take off the circuit board and you should be able to turn it on and off.
Jul 06, 2008 | Gateway (SL1450-30151382) PC Notebook
Gateway 7330GZ Notebook Logo
357 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
