Question about Tomtom One Europe v2 GPS Receiver
New purchase i just bought the unit, and it turns on for one second and has a picture of a briefcase and a picture in the lower bottom of alittle man carrying a bag. Is it just not charged yet?
  • aeroguy Nov 30, 2007
    I have the exact same problem (USA TomTom One 3rd Edition). It's brand new and I finished going through the initial preferences, turned it off, turned it on again, and I get the same screen as the original poster mentioned, then it turns off. Won't even connect to the computer.
  • obi1 Feb 24, 2008
    during uploading updates from tomtom site, it froze had to switch of tomtom and close down computer. Now tomtom starts up and switches off after 1 second, help please. i have tomtom europe v3
  • 143 Answers
Reset the unit by pushing a bent paperclip or pin into the hole on the bottom marked 'reset' turn it back on, plug it in & charge it via USB overnight or as long as you can in the car, make sure the led on the top is green, tap the bottom right of the screen & check the battery symbol on the unit says charging underneath.
If this doesn't help.
contact them about the problem...
Posted on Dec 16, 2007
How to Make a Brief Case on Windows?
follow this steps
  1. Copy the briefcase over to the second drive. You can do this in a multitude of ways, the simplest of which involves dragging the briefcase into the Windows Explorer window of the drive you want to sync to.
  2. Go to another computer and edit any of the files in the briefcase.
  3. When you are back at the computer you created the briefcase on, right-click the briefcase while viewing the second drive in a window and click "Update All". This will sync any of the changes you have made to the files with the computer.
Oct 20, 2016 | Computers & Internet
Water is collecting in the bottom of refirigerater, spilling out on floor. Leak in drain pan was caulked by repair man, but water is now statring to appear in the bottom of unit again. Can this be normal...
Check temp. settings and try to lower it 1 click, this will keep the unit working a little less, ddiminishing the condensatino.
Also try relocating the unit to a cooler spot, ie. away from the door.
Keep me posted!! Rate this post!!
Aug 12, 2010 | Kenmore Refrigerators
Switch on xbox withing 5 seconds a red ligh appears bottom right but if you turn the xbox on ots side the red light slips to the bottom right no sinal to television
This is the video chipset failing, couse: heat problem, the main board expands by the generated heat then cousing the solderings of the video schipset to brea, get the xbox to a repairs man.
Aug 28, 2009 | Microsoft Xbox 360 Console
Wont turn on
I'll quote GBATemp here:
the ds lite powers up for a brief instant, but then shuts off
potential solution:
disassemble the lower shell and check the connections of upper and lower displays (all three flexible cable connections).
You can view the full and detailed guide here:
Jun 14, 2009 | Nintendo DS Lite Console
My ds lite wont turn on i bought a new baterie and charged it with my cuzin charger and it still does not turn on it just goes on for 3 seconds and turns off and only the top screen blinks 1 and it just...
Your DS Lite is damaged and needs to be sent to Nintendo for repair.
Nintendo will likely tell you the unit is beyond repair and must be replaced.
If you want to avoid the middle man, you can always purchase a new DS Lite from your local electronics retailer.
Apr 12, 2009 | Nintendo DS Lite Console
Unit is freezing on the outside at the bottom and fan is not runn
hi! there,
occasionaly freezing on evaporator,severral factorcan be the cause since this is just almost two years,in this case if has no maintenance need to be clean your evaporator fin,debris ,dust particle obstruct the cooling effect blown by your blower fan,so freezing occured,this need maintenance perhaps they can check also the freon charge w/c is one of causes also,if under charge mostly freezing on lower bottom of evaporator occured,check if still on warranty date of purchased,call in on service center where you bought the unit or near service center of the branded name,if under charge you should ask the service man to find the leakage before recharging otherwise it will persist again the problem for a couple of day at time of warranty service,beside leak freon is bad for our enviromental athmosphere
this should be done promptly.cheers and have anice environment,don't forget to rate me,thank's
Apr 08, 2009 | Heating & Cooling
Sharp XR-10X Bulb works once then nothing
this is something which sharp didnt foresee!!!!!!!!!!
sharp has two identical models
sharp xr10x & the newer model xr10xl.both the lamps look alike , however both have a different rating & reverse connector!!
i.e both cannot be interchanged!however if u have the old xr10x & if u try to fit the new bulb which is lower in wattage, it will explode in 20 mins
if you have bought a used projector , then u wont know if someone has interchanged the ballast!!
as this model was discontinued 2 years back!!!!
so confirm the model , it is mentioned under sharp name or at the bottom
good luck
Feb 05, 2009 | Sharp XR-10X Multimedia Projector
Flashing Standby/Stero light and No picture.
How good is your picture when it did come ? Is it as good as it once was ? Or is it alittle washed out. If it is washed out the picture tube is weak . Sometimes turning up the screen control alittle would solve problem but if you turn it up too much you would have faint white line running diagonally. Now if you think the picture was good before you this problem video circuit would be your suspect . Jungle IC or something in the RGB circuits . Good luck
Feb 27, 2008 | Sony KV-35V35 TV
TomTom ONE
The current Tom Toms do NOT come with SD cards any longer. After December of last year, they began to preload the map information directly into the unit. If you had purchased a unit that needed an SD card, the main screen would be an animation of the card being put in the unit to "remind" you to insert the card. You may have a battery issue. How have you been charging the unit?
Jan 19, 2008 | Tomtom ONE GPS Receiver
Ice Cream Melting...
the ice on the evap may be the clue. there should not be excessive ice build up and if this has occurred, the ice can jam the fan. try removing the freezer back panel, defrost with a hair dryer, reassemble and see if it works. if it does, the fault lies with the defrost system
Jul 07, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
Tomtom One Europe v2 GPS Receiver Logo
163 people viewed this question
Top Tomtom GPS Experts
Martin Murray
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
