SOURCE: My Jennair Side by side has ice in freezer bottom and leaks water
This sounds like the defrost drain line is clogged and frozen. Every 8-12 hours the defrost cycle melts the ice buildup on the coils and is supposed to drain out to the pan under the fridge. Once this is blocked or freezes up the next cycles continue to put liquid water over the existing ice which then freezes, etc. till finall the area is frozen enough for water to find it's way out the door seals. You will need to take the back interior panel off the freezer side to view the coils and drain line. It will take lots of hot water to melt the ice in the drain area and the drain line in order to run a cleaning tube (basically a piece of 1/4" tubing like the water line tubing a couple feet long that you can force down the drain to make sure it's not plugged). Once you push the cleaning tube down the drain and can see it come out the other end in the drip tray pull it back out and pour hot water down it once more to watch that it drains fast. That should do it!
SOURCE: Ice and water on bottom of freezer
sjlobo, sounds like your defrost drain pan is frozen over or has some gunk in it. When the unit goes into defrost the water is running onto the freezer floor and out the front. Remove the lower bin and check the drain hole. You may have to remove the freezer back panel. If you can, just use some very hot water and some sort of baster to unfreeze the drain. Check this first, Catriver..post back.
SOURCE: Excessive Frost and Ice Build up in Freezer
sounds like you have a clogged defrost drain tube. removing back panel of freezer will give you acess to drain trough, melt away the ice with a hair dryer, youll find a drain hole under there somwhere,pouring boiling water down the drain will clear it pretty quickly( i use a steam machine purchased from the infomercials works awesome, after you clear it and all water drain down tube wrap a piece of solid copper wirearound the heater( black calrod heater right above the drain trough) and stick it in the whole maybe an inch or so. now everythime the heater comes on to defrost it will prevent the hole from freezing over
SOURCE: maytag side by side freezer leaking water and icing in bottom
Defrost drain system is plugged and not draining out the back and into the drain collector. There is normally an air trap in this drain line under the back and behind a fiber removable panel. Check this trap and make sure it is clear of any blockage. You will then have to defrost the freezer and clear out the ice. Don't forget to replace the back fiber panel.
SOURCE: water leaking and ice in bottom shelf of freezer
Chances are you have a bad seal around the door if it's leaking from the inside which causes the ice to form as well, or if it's leaking from under the freezer you lave a bad heating element that evaporates the water collected in the pan under the freezer or you have a clogged hose that goes to the pan under the freezer which also causes the ice to form because the water has no place to go. Defrost and try to find a way to blow out the hose that goes from your freezer to the pan under the freezer and that should take care of your problem.
