SOURCE: dish feels hot but not drying
sounds like your heating element is not working prtoperly or you are not washing in very hot water stop washer in middle of cycle and open it if steam come out hot steam be careful keep face away when you open itif not hot that could be the problem,A appliance serviceman once told me if water is hot enough and end of wash and rinse cycle not to run the dry cyvcle just open dryer a few inches and let the steam out Run hot water over a plate or a pot and set it in the drain tray in your sink notice how fast it dries itself while draining in the tray very hot water in a dish washer dopes the same good luck with this problem I hope my advice helps you oh yes one more thing always run the hot water till it get hot before you turn your dishwasher on
SOURCE: Dishwasher not drying
the dishwasher does not have a heating element to dry the dishes. If you wash glass or ceramic dishes and cups then the rinse cycle makes them hot enough to dry without a heating element but if you wash a lot of plastic this process does not work very well. Open the door after the load is washed and leave them to air dry for several hours and you will be fine.
The manual states that there is no heating element to dry dishes. The high heat content of porcelain, glass, or metal dishes enables them to get hot and stay hot long enough to get dry without a heater. Plastic does not have nearly as high a heat content so they cool down much more quickly and don't get dry.
SOURCE: Dishwasher runs for way too long then doesn't dry dishes.
the problem you have is probably in the heat circuit. its trying to heat the water up and keeps running because the water does not get any hotter. you need to check the heater wires and a couple of sensors as well as the heater itself.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
SOURCE: The dishes come out with a fine white powder on
Check your heating element..
Dishwasher Problems The Heating Element not Working
http://www.fixya.com/support/r4589033-dishwasher_problems_heating_element_not
Dishwasher Maintenance
http://www.fixya.com/support/r4319937-dishwasher_maintenance
heatman101
