Question about Tivo Series2 TCD649080 Video Recorder
Series 2 tivo
I cannot get any type of video on my series 2 tivo. no picture no nothing. if i unplug the ribbon cable from the power supply the tuner pushes through.
  • 38 Answers
You shouldn't unplug the ribbon cable and power on the unit, ever!
Make sure the ribbon cable is 100% in the motherboard, and the front ribbon cable as well, also ensure they aren't damaged. If you can't even get the startup screen, or any type of video output, then your motherboard is most likely shot and I'd see what tivo can do for you.
Posted on Nov 28, 2007
Tivo Series 3 TCD652150 has has a blank display on Tuner 1. Tuner 0 works fine, and Tivo menus will display on Tuner 1 so I assume tuner 1 is not processing the audio/video signal. I feel I'll have...
The Tivo Series 3 uses two CableCards, one for each tuner. It is possible that the CableCard that is responsible for receiving channels on Tuner 1 is defective, has become corrupted, or otherwise is not paired correctly. Call your cable provider and have a tech look at it.
Jan 16, 2011 | Tivo TCD652160 180-Hours HD DVR
Changing Channels with Series 2 Tivo
Make sure you are using the IR cable to control the Cable Box.
Make sure that you have already done a guided setup again from the tivo box.
Jan 04, 2010 | Tivo Series 2 80-Hours Video Recorder
TiVo has power but something is up.
Replace the power supply.
Sometimes, it will just have enought power for the LED and Fan. But not enough for booting up the drive correctly.
Apr 03, 2009 | Tivo Series 2 80-Hours Video Recorder
Are there different types of cablecards?
They're lying to you, to charge you more.
A cable card is a cable card is a cable card.  If your provider stands by their "special card" BS, switch to a new cable provider.
They're probably trying to scare you into getting their DVR instead of Tivo.  And it's not the same, ever. Tivo is far superior to any other DVR on the market, free or not.
Mar 19, 2009 | Tivo Series3 Dual-Tuner HD DVR w/ 300-Hour...
Motorola DCT 6200/1000 seems to only have one audio output?
There are three options:
1) Connect the Tivo using the coax output of the cable box into the cable input of the Tivo
2) Exchange cable boxes with your cable provider for one with composite output jacks. It may require you to use a Motorola box that isn't High def depending on what your provider has. I know Comcast has a Motorola HD tuner that has composite outputs as well as component.
3) Upgrade to a Series 3 Tivo. Those units are designed for High Def. Use HDMI cable hookup.
Jan 17, 2009 | Arris DCT6200 DTV Receiver
I'm getting cable channels but no high def
Your TiVo is only recording basic cable (i.e., channels it can receive without a cable box). You will need a digital cable box from your cable company to record channels above 99. If your TiVo is a Series 2 you will not be able to actually record in HD either. You should be able to record the HD channels from the cable box, but they will not be HD quality. (This is my current setup and while the picture quality is much better than basic cable, it pales compared to bypassing the TiVo and watching HD directly off the cable box to the TV.)
Dec 23, 2008 | Tivo Series2 TCD649080 Video Recorder
Tivo turns off TV unexpectedly
You could have a faulty power supply going out...
I would replace the power supply.
Jan 01, 2008 | Tivo Series 2 80-Hours Video Recorder
Tivo turns off TV
For some reason your Tivo is tripping the internal breaker of your TV. Check the cables and see that they are not damaged and are connected properly (all the cables that hook up to the Tivo). If you have a spare set of cables, try them to see if the TV still turns off.
Ps2 slim will not power up
usually, there is a problem with a ribbon cable of power/reset switch. Try using a replacement ribbon of the same type.
Nov 01, 2007 | Sony PlayStation 2 Slimline Console
Tivo not working
Looks like you only have one tuner hooked up (one cable ) to your tivo. You need 2 in order to work properly
Oct 28, 2007 | Tivo Series2 TCD649180 DTV Receiver /...
Tivo Series2  TCD649080 Video Recorder Logo
144 people viewed this question
Top Tivo Televison & Video Experts
Computer Repairing
Computer Repairing
Level 1 Expert
Are you a Tivo Televison and Video Expert? Answer questions, earn points and help others
