Dishwashers Logo
D
David Baldie Posted on Sep 18, 2018
What could be the issue with my Kenwood KID60S10 dishwasher after resetting E4 code?
I reset float switch on my Kenwood KID60S10 dishwasher tilting the machine forward and drained water sitting in bottom and reset the code. I put a cycle on which lasted roughly 5 minutes and now code is back on again.
1 Related Answer
ercupa190
ernesto cuadra
  • 12223 Answers
  • Posted on Jun 19, 2012
SOURCE: kenwood dishwasher kid60s10 error code 3.4
see your instruction manual, go to the section troubleshooting and see th error code and proceed.
if you do not have go and download www.retrevo.com
God bless you
I tilted the dishwasher got the water out but still says E4
Full 'make model (what it is)' in all question please.
Generic E4 Error fixes
The E4 error code relates to there is too much water via the inlet or a possible leak. You have acted correctly by checking the fitting and joints for leaks.Jun 16, 2021
My dishwasher keeps throwing the code e4. I've checked all
JustAnswer https://www.justanswer.com > Appliance Repair
Nov 26, 2023 • Dishwashers
1helpful
Kenwood KDW243A,
The machine still thinks it has flooded hence the pump continuing to operate. You have already checked the float and microswitch. Make sure the microswitch has actually switched off. If the switch shorted internally, it may be in its closed position and still causing it to think the machine has flooded. It should be open circuit when no water is present in the base. It could also be possible the pressure switch (water level switch) is faulty and reading a full of water situation, when the machine is actually empty.
1helpful
3answers
How to fix error e4 code on kenwood dishwasher
This is the flood code. Shut the power off at the main and remove all the water from the inside manually and then reset and try it.
How do I reset the E4 error code on a Kenwood dishwasher KID60S10
HomeForumDishwashersKenwoodHow to fix error e4...Share on FacebookShare on TwitterShare on Google+Share on PinterestShare by Email
Question about Kenwood Dishwashers
Posted by Val Lucas on May 04, 2018
Talk to a RepairmanCommentFlag
More
Rick siegel
Contributor14 Answers
Posted on Apr 01, 2019
Helpful0Not HelpfulCommentFlag
6ya staff
SOURCE:
6ya.com
Instant Repair Help over the Phone
6ya.com
Save Time & Money by instantly connecting to...
Helpful2.3KNot HelpfulFlag
lacocad
SOURCE:I have a kenwood KDW12SL3A.
Just got one of those at weekend and had e4 code-looked up on here and gor tis solutionwhich sems to work!
To clear the fault you need to remove the two baskets from the dishwasher.
Slide it out from under the worktop and lean it forward to about 45 degrees.
If it is already full of water, turn on the power whilst pushing the programme button, this sets up a pump out program
Posted on Jun 30, 2008
Helpful0Not HelpfulFlag
leejewsbury
SOURCE:I HAVE A KENWOOD KDW12ST3A
i hav a kenwood kdw12st3a and the e4 code came up and it said in the manual it had overfilled but it did'nt tell you how too fix it can you help
Posted on Oct 29, 2008
iano086
SOURCE:powerpoint dishwasher E4 error code
The solution below applies to a Powerpoint dishwasher but is probably a generic one for E4 problems - given that brandnames are frequently badges of convenience for made-in-china products.
The problems cause and solution goes as follows:
Problem:
Any water that leaks (for whatever reason) from the internals of the machine finds it's way down to the lowest point of the machine - down under the washzone and into the area where all the workings of the machine are located. There's a sensor there (a polystyrene float operated switch in fact) that detects this water - causing the machine to empty and go into error 4 (E4).
The solution will depend on the nature of the leak. If it's due to one of the various seals on the floor of the washer leaking or there is some problem with water level controls then that will have to be repaired first - otherwise you'll keep on getting the error. In my case however, the "leak" was actually a design feature of the machine and is easily rectified.
Open the dishwasher door fully and look at the floor of the machine where it meets the bottom of the door. You'll see a couple of plastic tubes protruding from the floor by about 12mm - one to the left and one to the right. Their function appears to be to act as an overflow if the water level in the machine gets too high (for whatever reason). This excess water is directed down these tubes and into the bottom of the machine where it can be detected - rather than letting it spill out onto your expensive floor. The weakness in this system is that it only takes a soup spoon of water to produce the error - something which might accidently happen during the course of a normal wash.
Options:
1) Leave the machine idle for a few days until the water evaporates. The sensor switch will reset and the error will be gone when you switch on.
For either of the following solutions, turn off the power to the machine by unplugging it or tripping the relevant switch at your fuse board
The stainless steel washcabinet is only slightly thicker than aluminium kitchen foil. Handle the machine gently and never force it otherwise you're in danger of distorting the cabinet.
2) Tilt the machine right the way forward so that the water leaves the area of the sensor. It'll flow back again once you level the machine but in wetting the floor area of the machine, the level at the sensor will be a little lower than before - permitting the sensor to reset. Switch on and the problem should be gone.
3) Pull the machine out from the built in unit to gain access to the right hand panel. Remove it (just a lot of philips screws holding it on) and you can just about see the polystyrene float (near the front) and the slightly depressed area underneath it - in which the water accumulates. You can poke a stick in with some tissue taped to it to mop up the water. Be careful not to disturb or damage the float.
note:
I've had this problem occur twice in as many years. If it keeps on occurring then you likely have a genuine problem with water level controls during filling or a leaking internal seal dripping water into the bottom of the machine.
Don't be tempted to block the overflow tubes - a genuine overflow could destroy your kitchen!
Posted on Feb 21, 2009
rory166
SOURCE:Kenwood dishwasher KDW12SL3A
Sounds as though the drain is blocked partially. E4 is the overfill code. Try cleaning out the drain.
Posted on Jan 24, 2010
isadan
SOURCE:how to reset error code e4 on delonghi dishwasher
Remove all dish trays from washer, unscrew and remove lid off salt softner, tip machine on side untill all water drains from the salt softner, replace all trays and softner lid and machine should work again.
http://www.fixya.com/support/t26966796-fix_error_e4_code_kenwood_dishwasher
1helpful
2answers
Hi... I just bought Electrolux Dishwasher ESF2433W. When i first time turn it on, light at "Normal" button keep on flashing with beeping sound. After checking the trouble shooting manual, it actually refer...
E4 Overflow
Sometimes during trasport it is possible that styrofoam float mechanicaly activated overflow microswitch. So, you should check complitely overflow system.
At any time, if overflow micro-switch act and keep for longer than 2 seconds, the E4 would occur. When E4 occurs, the drain pump will run until flowmeter keep motionless for 2 minutes (if the model with the pressure switch (83/63),drain pump would run till the pressure switch reset and continue draining for 60 seconds.) and all the other components will be stopped immediately. At the same time, the buzzer will alarm for 30 seconds and error 4 will be shown. Note: Priority level of E4 is the highest. E4 operation is valid after other error operations have done. When E4 operation has done, all the others are invalid.
Dado
Kenwood dishwasher kid60s10 error code 3.4
God bless you
Jun 18, 2012 • Dishwashers
E4 showing on the panel KDW60X10
The Kenwood KDW60X10 shows the E4 code when there is a water leak or a problem with the float switch (or it's PCB board connection). This could be a leak at the tank, the hose, or that the drain pump's anti-flooding system has been tripped.
Disconnect the dishwasher from power and the water line. Look for signs of a water leak under the unit. If the hose is leaking, you may be able to replace or reseat the drain hose. (Also make sure that there are no kinks in the hose.) Note: sometimes the leak is in the plastic where the drain hose connects to the dishwasher. That is harder to fix.
If the tank is leaking, replace the entire unit. For the other possible problems, you should consult a repair tech to narrow down the issue. Float switches are easy enough to replace; the PCB board and the anti-flooding system are not as easy to reset.
The manual for your dishwasher is available here: http://www.partmaster.co.uk/company/partmaster/manuals/Kenwood%20KDW60X10.pdf .
I hope this helps.
5helpful
2answers
Kenwood Slimline Dishwasher KDW8ST2A
I have a Kenwood Kdw8st2a and have been constantly plagued by the E4 overfill error.
Lifting the front of the dishwasher and tilting it backwards seemed to clear the E4 error only for it to come back after the next wash.
I found eventually that the connection to the U bend under the sink was too narrow and was almost blocked hence the dishwasher was not emptying properly.
I disconnected the dishwasher waste pipe and ran the waste into a bucket for about 6 cycles and it worked fine.
Eventually drilled through the kitchen wall and fitted a lower direct waste pipe to the drain. Overkill maybe buit it hasn't done an E4 since.
May 21, 2008 • Dishwashers
9helpful
3answers
Error mesage E4
E4 commonly means an overflow detected in the bottom over flow tray - try removing the kick board from the front of the machine - you should see 2 plastic black panels about 4 inches wide each, using a flat edged screwdriver pop the panels off and you will see the mechanics of the machine - the base is classed as the over flow tray - when water fills this tray a polystyrene float is pushed up and an E4 error code is detected - tilt the dishwasher back and allow the machine to dry out before trying it again - this should work unless the water seal around the filter basket is broken - in this case an engineer should be called to replace this part. Hope this Helps.
Thanks
Donna
Top Kenwood Dishwashers Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a Kenwood Dishwasher Expert? Answer questions, earn points and help others
