Question about ViewSonic N2750w 27 in. HD-Ready LCD Television
Viewsonic 32" TV
I see some of the seals slowluy showing up on the right hand corder. These look like a drip from the sealant pf the front frame. Can the front be opened without damaging the internals?
You can open it when remove all screws at the back, from the stand also (under the TV).
Then carefully remove the snap-in shell ( front and back). TV is one compact part and plastic shell is snapping ( front and back) + stand, on the screws.
Posted on Jan 17, 2008
Hi, I have a fiat doblo cargo 2003, leaking oil. When I park up - the oil drips closer to (but not right at) the front of vehicle, and to the left hand side (drivers' side) - could this be the oil...
Try wiping the engine off in that area with some rags, then watch for where the oil leak comes from. If it's the filter seal, you should see oil on the filter dripping off.
Oct 08, 2012 | Cars & Trucks
My 32" Philips LCD TV makes a annoying buzzing
The main cause off buzzing from these sets is the transformers on the psu. This can be solved by sealing the transformers with a sealant spray.
Jan 21, 2011 | Philips 32PF5531D 32 in. LCD Television
My Philips TV, 32 in LCD, model 32PFL3505D, makes an intermitent buzzing sound, mainly when there is text on the screen with a white background like on advertisements. What is the problem and can it be...
The buzzing sound comes from transformers on the PSU. The transformers can be sealed using a sealant spray which dries and hardens. You can also check your picture settings in the menu, if there is a "vivid" option, pick it and your buzzing will not be heard.
Jan 11, 2011 | Philips 32PFL3505D 32 in LCD TV
I'm looking for an estimate of repairs. I have a leak in the upper right side of the windshield which leaks into the front A frame, then down into my passenger foot area. When it rains the mat and floor...
It is possible you have a plugged drain and not a seal leak around your windshield; a hands on diagnostic is the best bet and so is a second opinion!! I feel you should try to locate the leak yourself by first putting some colored napkins in a few places like along the side of the windshield post, under the dash, at the floor to side wall, etc - anyplace water could be entering the passenger compartment.Make sure your door is closed securely and run a garden hose at about half flow for 1 minute over the top of the windshield. Wait 2 minutes then check your napkins for wetness. If none present then flow water over the top of the door 1 minute, wait, then check your napkins again. The problem may be in the door weather seal and not the windshield and this test should help you pinpoint the problem area. If during these tests you find wet napkins, try to follow the wetness up as high as you can and see if there is a bubble between the rubber and the body of the car. You can buy a tube of windshield sealant from an auto parts store or another store like Walmart and try to seal it up yourself. If there is a bubble or lump, break it off with a screwdriver and back fill that area with the windshield sealant. Dry the affected area with a blow drier on high for at least 5 minutes before applying the sealant so it can stick - it won't adhere to a wet surface and you can wipe off any excess with a napkin. Give the sealant 24 hours to cure and retest. Other than this, the sealant around the windshield will need to be replaced. I hope this helps!!
Dec 15, 2010 | 1998 Toyota Celica
Hole in front seal round inside of door. need part and someone to fix please - or could I fix it myself? Thanks, Simon
your best bet is to replace it. here is what you do:
Look in your owner's manual or study the current seal to see how it is attached. If it is attached with bands, there will be one or more spaced around the seal. Remove them following manufacturer's instructions.
  • Step 2 Pull the seal from the door rim. For seals that are attached with sealant, you may need to slide a finger under the end and push it up while you pull it free with the other hand.
  • Step 3 Wash the area thoroughly with a degreasing cleanser. This will remove all traces of dirt, grime and old sealant around the area.
  • Step 4 Slide the open end of the new seal onto the door frame2.gif. Make sure the fit is snug and it is completely slid into place.
  • Step 5 Glue around the join with the sealant or reattach the bands. Allow sealant to dry for at least two hours before running the machine.
  • Oct 02, 2009 | Bosch Classixx WFL 2066 Front Load Washer
    My LCD TV model 32 lxLX2R has vertical black lines down right hand side on all chanels. Can any one give a solution of how to get rid of them 21st April 2009
    Apr 21, 2009 | ViewSonic N3251w 32 in. LCD HDTV
    2004 Expedition Sun Roof Leaks
    you have 2 drains in the front that go down the a pillars and dump near the fenders.
    The rear usually go down the B pillar or C pillar and out thebottom near the rocker panel.
    Blow them out from the top with compressed air and make sure you have air flow at the exits.. Open the roof to see drain holes in the four corners.
    • The roof opening panel leaks
    • Roof opening panel adjustment.
    • Front rail seal.
    • Drain tube attachment points.
    • Roof opening panel water trough and seal.
    • Roof opening panel drain hose.
    • Roof opening panel seal.
    • Roof opening panel.
    1 is the drain hoses
    Apr 12, 2009 | 2004 Ford Expedition
    Viewsonic N3260W made loud pop and will not turn on.
    We got the part in today and the hubby fixed the tv. It is as good as new. We are very happy with our $62 purchase.
    Go to
    FSP228-3F01, FSP Open Frame Power Supply Replacement for Viewsonic N3260W - 32" LCD TV
    It worked like a charm and took about 10 minutes to put in new part and put tv back together.
    Jan 04, 2009 | ViewSonic NextVision N3260W 32 in....
    Whirlpool Gold Dishwasher leaking from behind door
    could be water getting behind the lug that holds the dishwasher in place , I used some silicon sealant over the top and the dripping stopped
    Oct 18, 2008 | Whirlpool Gold 24 in. Built-In Dishwasher...
    Have a 32 " Viewsonic
    If you go to Viewsonics web site they say the following about your Model TV in the specs:
    INPUT SIGNALS TV/Video Comp. 480i, 480p, 720p, 1080i
    So it will indeed do 1080i
    Mar 10, 2008 | Televison & Video
    ViewSonic N2750w 27 in. HD-Ready LCD Television Logo
    96 people viewed this question
    Top ViewSonic Televison & Video Experts
    Are you a ViewSonic Televison and Video Expert? Answer questions, earn points and help others
