Question about Maytag Atlantis MAV6000 Top Load Washer
Washer won't work... Period
My uncle has a maytag atlantis washer and one while washing, opened the door to put a clothing item in and when he closed the door nothing happened. the washer would not work from then on...
  • Karl B Dec 29, 2007
    Have similar problem with a Maytag Atlantis MAV6000. It is empty from a previous load and now it is dead. Wont fill up and wont turn on. Checked the circuit and it is live but its almost as if it isn't getting any electricity. Do you think it is the same issue of a lid switch?
  • 213 Answers
The lid switch on the washer went bad. with out the lid switch working the washer cant do anything. its there as a safety to stop the washer when the lid is raise but when it goes bad it doesnt know if the lid is down or not so the washer wont come on
Posted on Nov 26, 2007
Is there any kind of recall on a Maytay front loading washer, model #MAH6500AWW? I am having problems with mildew in the rubber part and terrible smelling water in the bottom.
The cleaning process for your Maytag Neptune front-loading washer, for example, requires some time and patience. Over time, your washing machine will need to be cleaned. It can develop offensive odors through multiple wash cycles. This makes the washing machine less effective at cleaning the clothes you put into it. Maytag offers some sound advice for cleaning your front-loading washing machine.
  • Pour 2/3 cup of liquid chlorine bleach into the bleach compartment of the dispenser drawer of your Maytag Neptune front-loading washer.
  • 2
    Run your Maytag Neptune front-loading washer on the "Clean Washer" setting. Press "Start" to start the cycle.
  • 3
    Leave the door open once the cycle is complete to allow the inside of your Maytag Neptune front-loading washer to ventilate and air dry.
  • 4
    Look closely at the gray seal of the Maytag Neptune front-loading washer's door opening. This seal can have a buildup of debris or detergent residue.
  • 5
    Spray the seal with an all-purpose appliance cleaner and scrub away any debris or residue with a cloth or scrubbing pad. Dry with a clean cloth.
  • 6
    Remove the soap dispenser drawer. Press the release lever and lift it out to clean.
  • 7
    Take out the inserts and rinse them and the drawer thoroughly.
  • 8
    Wash with a mild soap and cloth to remove any residue. Dry thoroughly before replacing.
  • ALWAYS LEAVE THE DOOR OPEN WHEN NOT IN USE! This prevents the mold and mildew from forming once you get it cleaned.
    Aug 20, 2011 | Washing Machines
    Lost power to washing machine
    When you opened the lid to add clothes, your Maytag sensed a door lock fault and went into protective shutdown.
    Jan 04, 2018 | Maytag Atlantis MAV6000 Top Load Washer
    Maytag Atlantis - dead and full of water
    with the atlantis i would have to say yes
    open the control panal,
    pull out the lid switch and unplug it,
    give it a shake if there is any rattle
    thats your problem
    you can order a new switch and plunger from
    appliancepartspros.com
    looking for part number
    AP4008646 about 20.00
    Oct 17, 2009 | Maytag Atlantis MAV6000 Top Load Washer
    Need to replace Lid Switch for Maytag Atlantis 2002 Washer
    Hello, I can help you.
    Let me explain to you how the Maytag washer lid switch works.
    The lid switch is located on the controls panel, and is activated by opening and closing the washer door. The purpose of the lid switch is to prevent the washer from working with the door open.
    It is a safety device to prevent the user from sticking their hands inside of the washer while the washer is agitating or spinning.
    When the washer lid switch stops working, the result could be that the washer won't wash, drain, spin and in some cases the washer will not work at all.
    You will need a multimeter to check the internal contacts on the washer lid switch.
    You will also need to use the wiring schematic to see what contact should be close when the lid switch supposed to be on.
    You will need to remember that the Maytag washer lid switch is one of the first parts that you will need to check, when the washer don't want to start filling, agitating, draining or spinning.
    Jun 13, 2009 | Maytag Atlantis MAV6000 Top Load Washer
    Maytag Atlantis 6451 noise when on and agitator doesn't work.
    it does sound like a bad motor.
    they are rather expensive on that machine,
    you would be looking at 300 or so
    May 28, 2009 | Maytag Atlantis MAV6451 Top Load Washer
    I put in a load this morning .
    The switch on the door, is it clicking when you open/close it. Sounds like the switch.
    May 09, 2009 | Maytag Atlantis MAV6000 Top Load Washer
    Will not spin Maytag PAV2300AWW top loader
    check your door switch. Many times a faulty door switch can prevent the spin cycle. When you locate the door switch, take a jumper wire across the connection and advance the timer to spin. If it spins with the jumper wire, you will need a new door switch.
    Jul 04, 2008 | Maytag Atlantis MAV6451 Top Load Washer
    Maytag neptune won;t rinse
    Check latch mechanism for alignment. Often operation of machine loosens latch mechanism causing internal switch for "door open (or ajar)" preventing rinse or spin cycle. Opening and closing door presses latch mechanism closing internal switch allowing for continue processing to rinse or spin cycles.
    Mar 24, 2008 | Maytag Neptune MAH5500B Front Load Washer
    Maytag Atlantis MAV6000 Top Load Washer Logo
    289 people viewed this question
    Top Maytag Washing Machines Experts
    Bill Long
    Ronny Bennett Sr.
    Ronny Bennett Sr.
    John Tripp
    John Tripp
    Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
