Washing Machines Logo
T
Tarnia Farnden Posted on Sep 17, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi my Simpson eziset 9.5kg model 22s950 has oil splatter underneath the machine and making noise could this need bearings replaced and if so is it difficult to do myself. Thank you
Peter
Level 2:
Champion:
  • Simpson Expert 203 Answers
  • Posted on Oct 07, 2018
 Peter
Simpson Expert
Level 2:
Champion:
Answers
203
Questions
0
Helped
97356
Points
471
Oil will be coming from the gearbox. Oil seals can be replaced if you can source the seals where you live. If gearbox shafts or bushes are worn then a new gearbox would be needed, Machine has to be completely stripped down & both bowls removed from the cabinet to do the work. Tub seal & bearings will need to be replaced as well. Lot of work & lots of tools needed.
5 Related Answers
Anonymous
  • Posted on Dec 29, 2008
SOURCE: washing machine lid switch
used my noggin and saved $20-00
hattonhall
Poppa Maddo
  • 372 Answers
  • Posted on Oct 25, 2009
SOURCE: simpson eziset 800 clothes tangle when washing
If you can use a lollipop stick to operate the lid switch while you leave the lid open, you will be able to observe if the agitator is going smoothly back and forth EVENLY or not. If it is tending to turn just one way....this will tangle the clothing like mad!
If this is the problem it could be the switching module or capacitor that needs replacing.
Testimonial: "i will try it thanks "
luisa_sgro
  • 713 Answers
  • Posted on Oct 03, 2010
SOURCE: Hi I have a simpson eziset 605 washing machine and
Hi Carlee just read your posting.Now the Simpson Eziset machines come in top and front loader versions.Which type is yours?Please reply with this additional information and I will help you rectify this fault.
Anonymous
  • 6277 Answers
  • Posted on Mar 21, 2011
SOURCE: Looking or a service manual
Unfortunately this forum does not supply any type of manual, installation instructions, electrical or schematic diagrams direct; it's just made up of ordinary guys and gals, probably at home and from all over the world, with experience of addressing problems and giving guidance for free on the web ;-0)
You will need to type into your search engine/web browser '(make) washer service manual' and you may be presented with a number of sources from which you can either download for free or have to pay a nominal amount. During the process you will be asked for the actual model number!
May I also suggest you try the manufacturer's web site direct? You may find, however, that it will supply schematics only to service engineers but good luck anyway.
John C.
richroth
Richard Roth
  • 9472 Answers
  • Posted on Aug 09, 2011
SOURCE: simpson eziset 750 - Model
This problem occurs due to a faulty lid lock switch. There is a update kit for your machine to resolve this problem. You will need to contact Simpson at the following number.
Simpson appliances are backed by a network of service agents and spares outlets throughout Australia.To book a service call please call 13 13 49. To order a spare part please call 13 13 50.
Richard Roth
The FixYa Team
Simpson EZISet 950 not spinning (model no 22S950)
It could be many things. It the load is large and heavy, the machine electronics won't allow fast spin if the load is not even and even the slightest wobble will stop higher spin speeds. Here are a few things you can try. Split the load into two or three and then do rinse and spin.
Other possibilities are a slipping belt due to the weight, or the speed processor on the motor.
When our Eziset 800 washing machine is on spin cycle it is so loud we wonder whether the thing is going to take off?!!
It is so common that the washing machine can make terrible noise in many ways and is a common fault. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that machine is vibrating when it is running then the motor /drum suspension has to be inspected. Since these fittings are located on the underside of the machine it is important that you look for the noise with a good inspection lamp. Manually turn the motor and drum and listen for the noise, if so the motor bearings, the drum agitator shaft and fittings must be checked. Also the suspensions which include the shock absorbers and springs, the body clamps must be checked to be in correct alignment and not changed in position. Tightening of the mounting is also very important. Finally in most cases a drop of OIL or smear of grease on the moving parts cane solve most issues.
Check this link :
http://www.espares.co.uk/advice/washing-machines/a/7/1210/wobbly-washing-machine-or-tumble-dryer.html
For replacement of bearings check for tips on this visual link: http://www.espares.co.uk/advice/washing-machines/a/7/1401/how-to-replace-the-bearings-on-a-washing-mach.html
Simpson error code 5p
I have a error code Ld come up on my Simpson eziset 5.5 kg top loader washing machine what does that mean ? Also is it possible to replace a sensor battery for that. Model and what size battery replacement do I need to ask for
8helpful
Simpson eziset 750 manual
Hi our eziset 750 simpson washing machine has stopped working. It randomly just turns off and then will start again few days later. Cheers
4helpful
Simpson washer 22S950 not spinning..not agitating..water pump works...L6 come on the screen...bipps most of the time...part of numbers missing on the screen..
simpson washer 22S950 not spinning..not agitating..water pump works...L6 come on the screen...bipps most of the time...part of numbers missing on the screen..
24helpful
4answers
Simpson EziSet 750 washing machine won't spin - what am I looking for to fix it? Appears to be working in all other respects.
the lid-lock button keeps beeping on my simpson eziset 750washing machine. how do i make it stop!
Top Simpson Washing Machines Experts
vince
Are you a Simpson Washing Machine Expert? Answer questions, earn points and help others
