Question about Samsung TXN3071WHF 30" TV
I have the exact same problem. mine has a yellow tint to it. im
Posted on Aug 11, 2008
  • Garrett Overman
    Garrett Overman Aug 11, 2008
    i have this model tv but it is black and every channel is a yellow tint all of a sudden.
Necesito el diagrama
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
Jul 19, 2014 | Samsung SlimFit TXS3082WH 30 inch TV
Flickering TV Problem
Some of their sets have a issue on the power supply board where it flickers(the picture) on scene changes and gradually gets worse.
problem with those sets is on the power board and some only require a jumper there to be removed.
Call samsung with the model number.
Jun 02, 2012 | Samsung SlimFit TXS3082WH 30 inch TV
My Samsung TXS3082WH 30 inc wide screen TV seems to be losing color and going in and out and i notice when you watch cartoons its fine but when it goes to actual shows or channels with normal footage it...
There have been a lot of problems with the Samsung sets, one dealer I know had so many complaints about the ones he sold he stopped selling them and switch to another brand and he has been trouble free ever since. To answer your question they have problems with the screens, color texture, lines, fade out to name a few, from what you have described you have at least two or three issues, considering the history I would replace it.
Jan 07, 2011 | Samsung SlimFit TX-S3082WH 30" TV
My television is a Samsung Slimfit tx-t2782 and I'm having problems with the tv staying on. Everytime I plug it in it comes on for a few seconds it shuts itself off. I was wondering if there is anything I...
I AM HAVING THE EXACT SAME PROBLEM WITH MINE ! But before mine turns off, it shows a blurry squiggly red mark on the screen then shuts off and wont turn back on sometimes for several hours.. And everytime I CAN get it back on, I have to unlpug the whole thing and plug it back in...
Nov 09, 2010 | Samsung SlimFit TX-S3082WH 30" TV
I have a HDTV Samsung TV, Model #TXS3082WHX/XAA and I would to connect my desktop to the TV. Do you know what cables are needed?
Look for a monitor cable with 15 pin RGB plugs on each end, that will transmit the video portion of the signal so you will need an audio cable with 3.5mm plug on each end also, there are RGB cables that have the audio cable together as one big cable.
Good Luck !
Feb 09, 2010 | Samsung SlimFit TX-S3082WH 30" TV
I left my tv on when I went to bed and the picture was fine. Then I woke up and turned it off. When I came home and turned it back on, the picture was blurry all around the tv except in the middle of the...
is the blurry all around the picture have different color like a smear of red, blue or yellow?
if it is i think the posistor of your tv is not working. it is the one who activate the degaussing coil around the picture tube the prevent color miss-landing upon opening your tv set.
Aug 11, 2009 | Samsung SlimFit TX-S3082WH 30" TV
Samsung SlimFit TX-S3082WH Blurring on Left and Right Sides
your picture tubes is going bad. i've had 5 yes 5 of these tv's replaced by samsung/bestbuy. i've kept buying the PSP (product Service plan) now my most recent tv is doing the same. samsung no longer makes the picture tube for this model. i've already called them. it was a nice tv. i've gotten about 6 months out of each model. I'm moving on the LCD, nice rca 32 inch HDtv model at walmart for less than 500.00.
Dec 28, 2008 | Samsung SlimFit TX-S3082WH 30" TV
TV takes forever to come on and then very dark
IM Afraid unit required to be serviced , problem at the inverter transformer or faulty capacitors at the POWER SUPPLY unit , hope this helps AJ
May 25, 2008 | Samsung SlimFit TX-S2783 TV
I have a Samsung CRT slimfit that I bought in 2006. It has worked splendidly until about 4 months ago and suddenly I have started to notice the edges of the screen about 2-3 inches on both sides have...
In my experience from doing Samsung's warranty work on slimfit sets, they have issues with picture tubes causing problems on the circuit boards. Many times I would replace a board only to have it fail a short time later. The wide crt draws a large amount of current and many have purity (discoloration around edges) problems. I would suggest you try contacting samsung to see if any recall exhists on these and if that doesn't work I wish you luck having it repaired properly for under 275.00
May 21, 2008 | Samsung Televison & Video
Blurry edges
I own the same model of tv and have owned it for over 1.5 years. I moved with it twice. I had this problem about a month ago. On both vertical sides the screen became very fuzzy, yet the center remained clear. When turning the tv off and on I also noticed very wierd red, green, and blue lines streaming across the screen before the picture comes up or after it fades. I found no solution or cause to the problem. But I had two "long-boy" speakers from my panisonic 5.1 surround sound system setup right next the tv on either side. I set the center channel on top of the tv with the receiver on the shelf below. I thought well maybe some how the speakers were cause some sort problem in the tv. I moved the side "long-boy" speakers from directly next to the tv to about 6" away and removed the center speaker from the top of the tv. After several days of normal use of this configuration, the tv turned like normal and the fuzzy edges were gone. The symptoms lasted for around two weeks, and the several days after I moved my speakers. My only guess is that without a deguassing feature, it took several days for the magnitism to return to normal after repositioning my speakers.
Mar 17, 2008 | Samsung SlimFit TX-S3082WH 30" TV
Open Questions:
See all Samsung TXN3071WHF 30" TV Questions
Samsung TXN3071WHF 30" TV Logo
170 people viewed this question
Jerry Greenberg
Jerry Greenberg
