Seagate FreeAgent  (ST305004FDA1E1-RK) 500 GB USB 2.0 Hard Drive Logo
Posted on Aug 03, 2009
I have a 500 gig Seagate Free Agent external hard drive that I am having problems with. The problem is that the amber light on the hard drive comes on solid (bright) at initial start up, but then goes dim then bright, dim, bright etc....
  • Anonymous May 11, 2010
    does the drive work?
    is it making any noise?
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Aug 03, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
393
Points
Windows - delayed write failed
Windows was unable to save all the data for the file I:\$mft.
The data has been lost. This errors may be caused by failure of
your computer hardware or network connection. Plese try to save elseware.
What is the AC DC adapter spec for SEAGATE 9NK2AE-500. i lost the original adapter that came with this external seagate freeagent harddrive.
most of these external hard drive units work with a 12V 3 amp DC power supply like this one
OEM AC POWER SUPPLY SEAGATE 9NK2AE 500 Free Agent HDD
Make sure you get the correct power connector for your country.
2helpful
My seagate 500 gig free agent desk external drive has suddenly stopped working. It was working fine 2 days ago and then yesterday it apparently wasn't connected so I reconnected it and then it seemed to be...
Do a FULL POWER DOWN Reboot. and try a different USB outlet in the PC... same Laptop to see if it is in your PC that is causing the problem.
Note: Most of those Drives do stop unless they are connected to the PC... energy savings.
If that didnt work... you could have a failed drive. Seagate should help you do some diag if it is in warranty... typically 3 years.
How do I install my seagate freeagent external harddrive into my macbook? my computer keeps asking whether I want to erase everything on the hard drive first. I'm afraid it will erase any software that...
the soft ware that comes with it will also be erased, as it is a windows based identification,seagate free agent has mac utilities on its site, try to find out on www.seagate.com. you will find one for mac format and mac installation .
2answers
Seagate free agent pro 500 gig external hard drive NOT RECOGNIZED
You better check with the Seagate people. This seems to be a problem with the casing. And since you're under warranty, you can get a replacement.
2helpful
Seagate 500gb Free Agent Ex Hard Drive - Class Action siut
DO NOT buy a Seagate freeagent drive under any condition if it comes as a gift return it or re-gift to some one you don't like. Like so many others my 500GB external drive just quit working. Has only been plugged in about 6 times and then back into a cabinet to keep safe. In 10 years between 2 workstations 3 laptops and 4 external drives. The only drives that have ever gone bad are the Seagates and newer Maxators. I still have 4 Western digital drives that still work and get used in an external case for back up. They have never failed. Seagate should be responsible for data time and mental anguish.
Seagate 500 gig external hard drive problem
Your computer must have a firewire connection.
2helpful
4answers
Help for Seagate Free Agent 500 GB external hard drive
465.66 x 1024 x 1024 x 1024 = 499,998,617,764 bytes. The problem is the definition of gigabytes.
Top Seagate Computers & Internet Experts
Sean Wright
Sean Wright
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
